Old 10-02-2011, 12:54 PM
flmedic911's Avatar
Member #19216
Lightbulb Help with 90cc sportsman PLEASE!!!
2003 Polaris Sportsman 90cc...had old gas in it. Took out carb, cleaned it, cleaned gas tank out, fuel lines, etc. It starts up okay...but when I try to give it fuel, it boggs down and dies...if I turn the fuel off when its running...when the carb is just about empty...the idle kicks in perfect, and it runs like a brand new atv for about 5 seconds. I have also replaced plug, and filter. I have taken the carb apart three times, and re-cleaned just to see if that helped. Jet is clean...Oil res. is full and it has new gas in it....and help would be great.
Old 10-02-2011, 01:07 PM
If shutting the fuel off with little fuel in the carb makes it run better for a few seconds, it sounds like it might be running way too rich.
Old 10-02-2011, 05:43 PM
dwhst9's Avatar
Member #11907
Send a message via AIM to dwhst9 Send a message via Yahoo to dwhst9
Stuck float? Float has a hole in it?
Old 10-05-2011, 02:46 PM
flmedic911's Avatar
Member #19216
float seems to work and move fine...no visable holes or cracks...maybe oil pump is not working right? Can I premix and just fill the tank?
Old 10-30-2011, 08:52 PM
drasser's Avatar
Member #19438
I went through the same thing, cleaned the carb, new plug etc. next time you start it put on the park brake or raise the rear drive tires off the ground. Rev it, if it bogs let off and tap the side of the carb a few times ( i use the back of a screwdriver) then try again to rev it. I found that tapping mine will after a few tries let it work properly. I looked for a carb rebuild kit but polaris does not sell them and I have not found after market rebuild kits. I have found the carbs on e-bay (probably from china) for about $50.00. Try the tapping and let me know if it helps. also does fuel run out the bottom if you leave the gas on?
Old 12-30-2011, 01:33 PM
polarisdave's Avatar
Member #21777
mine is doing the same but my petcock still flows gas even tho it is off. seems like it runs perfect at idle but go to rev it and it seems like its starving for fuel i took the spark plug out and the tip is whitish which tells me its lean (not enough fuel)
05 sportsman 90 carb problem
2003 polaris predator 90 carb adjustment
2003 polaris sportsman 90 fuel
90cc polaris sportsman carburetor
90cc sportsman porlais
carburetor for a polaris 90 cc
cleaning 90 sportsman carburetor
how do you fix the vacuum for the gas tank on a polaris 2003 sportsman 90
how to clean a carburetor on a polaris sportsman 90
how to clean a polaris 90cc carbs
polaris 90cc carburetor replacement
polaris 2003 90 carb rebuild kit
polaris 90cc carb rebuild
polaris 90cc seems to run out of fuel when ridding
polaris atv 90cc sportsman
polaris sportsman 90 no low torque
polaris sportsman old gas
sportsman 90 running rich
sportsmen 90 clean carb
07 sportsman 90cc crank bearing ron_a_tron Polaris Sportsman 2 07-08-2011 04:27 PM
90cc Sportsman no low speed torque JEFF CRIST Polaris Sportsman 2 04-14-2011 03:44 AM
hard starting sportsman 90cc Fessman ATV Repair and Maintenance 3 04-22-2010 11:03 AM
90cc sportsman modracer4 ATV Repair and Maintenance 0 01-01-2010 06:59 AM
hard starting sportsman 90cc Fessman ATV Repair and Maintenance 1 12-25-2009 02:28 PM
