Old 10-03-2011, 06:49 AM
coryv4's Avatar
Member #19179
sportsman 500 silencer full of holes
i have a 96 sportsman 500 and the silencer is full of holes from rusting away and it make anoying rattle sounds from loose rust inside of it is it ok to run it without the silencer until i find a replacment will it hurt the motor/valves from lack of back pressure? i have a cobra slip on from a warrior 350 the slip on is the exact same diamater as the 500 exhaust will that cause to much back pressure would rejetting be required?the cobra pipe goes from being about roughly 3/4-1 inch in diamater then it slowy cones out to about 3inch in diamater with a spark arestor in it
Old 10-03-2011, 09:00 AM
cwlongshot's Avatar
WELCOME!!
That Warrior muffler isn't going to "hurt" anything, its a muffler.
BUT, its very likely it will have LESS back pressure, not more. Also, YES re-jetting your carb for it would be a good thing as a lean condition can occur as the exhaust will flow more and better causing more air thru the engine but not effecting the fuel...causing it to be lean.
1999 sportsman 500 silencer
muffler silencer for polaris 2000 sportsman
polaris 500 muffler silencer
polaris muffler silencer
polaris sportsman muffler silencer
polaris sportsman silencer
repair rusted polaris 500 sportsman muffler
slip on sportsman 500
holes in clutch cover mike101650 ATV Repair and Maintenance 2 04-23-2011 11:43 AM
00 sportsman 335 bog at full throttle vortecman07 ATV Repair and Maintenance 1 03-08-2011 07:10 AM
WTB muffler/silencer for a 1999 polaris sportsman 335 kymudd ATV Parts for Sale 1 01-04-2011 03:47 PM
98 Sportsman 500 bogging down at full throttle Muddermucker ATV Repair and Maintenance 29 10-03-2010 05:01 AM
850 XP in mud holes... slyder01 ATV General Discussion 2 03-14-2010 04:54 PM
