started my snorkel tonight
Got a question, every website I've found says use two 1.5" hoses to the air box but I'm curious why when the factory snorkel only measures 1.25" and is only one not two. Seems like a waste of material cost and something else to potentially spring a leak to run two. What are yalls thoughts. This is on the 700
2004 SPORTSMAN 500HO (HERS) 2500 LB WARN WINCH WITH SYNTHETIC ROPE
2003 SPORTSMAN 700 TWIN (MINE) 3 Headlight mod, Reverse bypass mod, temp gauge, volt meter and 2" lift, 28x10x12 & 28x12x12 zilla's, snorkel, 2000lb champion winch, reverse light, K&N air filter. Yearly maint done Feb 2012
