Old 11-10-2011, 02:14 PM
Saranac1973's Avatar
Member #3965
Headlight Conversion
Has any one tries a head light conversion on the sportsman. See a few kits to allow all 3 lights to come on with high beams.
Check out a couple of the below conversions.
1. Will they work?
2. Why did'nt Polaris do this conversion?
3. How much strain is on the charging system will this produce?
Polaris Mod's - Light mod, Reverse Overide and Others - TrackShare.com - Canada's Outdoor Connection
3 Headlight Mod Polaris ATV Lamps Kits Accessories Quad Parts Custom
2005 Polaris Sportsman 800 EFI
Old 11-10-2011, 03:27 PM
antoniodef's Avatar
Member #11247
Do a search. There is tons of info about it and many have done it with zero issues.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
cwlongshot's Avatar
Wink
1. Will they work?
IMHO the RELAY is the way to go!! Diodes get dangerously hot...
http://www.polarisatvforums.com/foru...ete-video.html
Old 11-11-2011, 03:28 AM
Beenthere's Avatar
Member #2620
Ditto!,
The relay is the way to go, works great and I've had no problems.
95 Magnum 425 4X4
Old 11-11-2011, 05:33 AM
Taz's Avatar
Taz Taz is offline
Member #18885
Send a message via Yahoo to Taz
I did the relay mod on my machine and am quite happy with it. I used the instructions found on this sight.
Previous Machine -
2004 Polaris Sportsman 400
ITP Mud Lite tires
3 light mod
Current Machine -
2008 Polaris Sportsman 800
Winch
60" Plow
Hand Warmers
Thumb Warmer
3 light mod
Work light mod (w/LEDs)
Old 11-13-2011, 03:57 PM
Member #3965
Thanks for the great answers..I'm gonna order the parts and attempt the conversion this week.
Old 11-13-2011, 05:09 PM
cwlongshot's Avatar
Follow the instructions and watch the video. Its easy!! 20 minutes you will have the lights Polaris should have given us form the get go!!
THEN, read up on the rev light mod and get the pieces parts for that one next!!
Old 11-14-2011, 04:15 AM
Member #1958
I agree with CW on the relay. There's no need to order parts. Just go to the auto parts store and get a relay for about $4 and some wire, connectors and heat shrink tubing.
03 sportsman 500 headlight conversion kit
2000 sportsman 500 headlight conversion
2005 polaris magnum headlight upgrade
700 sportsman headlight mod
atv light conversion kit
atv light conversion kit for polaris sportsman
front light on a 2011 sportsman
front lights conversion kits for 2004 polaris sportsman
head lights converson kits for sportsmans 700 2004
headlight mod polaris sportsman
how to get all three headlights on polaris sportsman to work at once
how to run all 3 headlights on polaris sportsman
lights hi and low conversion kits for 2004 polaris sportsman atv
polaris . 500 headlight mod
polaris atv 90cc sportsman 2006 headlight conversion
polaris atv headlight mod
polaris headlight mod
polaris led conversion
polaris sportsman 800 headlight mod
polaris sportsman headlight mod
pre-mix conversion Dahlbug Polaris Trail Boss 2 04-06-2012 05:36 PM
hub conversion klr650 ATV General Discussion 2 08-14-2011 11:16 PM
2-up conversion sportsman700 Polaris Sportsman 11 07-31-2011 09:33 PM
Conversion Cslaxer26 Polaris Sportsman 6 05-05-2011 02:57 PM
WTB 2006 Sportsman 800 headlight assemblies or gauge pod/headlight Angel of Death ATV Parts for Sale 1 09-06-2009 08:15 AM
