Old 11-12-2011, 01:44 PM
gregpro50's Avatar
Member #20388
Help pick carb for modded 400 Scrambler
I've got a '02 Scrambler X 400. I just bought it and it hadn't run in over 3 years so I have it all apart and am going through it.
The list of mods (that it came with) includes:
- Hot seat pipe and silencer
- Hot seat clutch kit
- Trail ported cyl with wiseco piston
- 38 mm mikuni carb
- V-force reeds and spacer
I am cleaning out the fuel system and was thinking of replacing the carb. Am I better off with a PWK 39 on it? I would like to use the stock airbox if possible. Right now there is just a K&N element fastened to the carb intake and I am worried about it sucking up junk.
My goal is to have a reliable trail machine. I've had a scrambler 500 in the past but this is the first 400 I've had. I'd appreciate some guidance in getting this set up right.
Old 11-12-2011, 02:02 PM
modded 400 polaris scrambler
modded scrambler 400
polaris scrambler 39 pwk carb
pwk 39 scrambler 400
pwk 39 setup polaris scrambler
scrambler 39 carb
scrambler 400 pwk 39
Help me pick a gear ratio for 2011 TB ? DirtFiend ATV General Discussion 5 07-24-2011 01:42 PM
Sons Modded Scrambler 50 is having problems RKMHD ATV Performance Modifications 4 06-26-2011 05:23 PM
modded 2000 scrambler did i get a deal coreyusmc Polaris Scrambler 3 02-20-2011 09:52 AM
will scrambler carb fit? kyle.payne ATV Repair and Maintenance 0 05-02-2010 06:23 PM
Weider 9930 Home Gym *Pick up only* redneck2725 Everything Else 1 03-26-2010 02:30 AM
