Old 11-15-2011, 09:19 AM
chevy4x494's Avatar
Member #19461
Adding a 400 carb to a 250. Jet help!
Alright, So i've got a 1999 Polaris trailblazer with a 250 2 stroke. The only mods i'm doing to it are: AAEN torquer pipe, carb off a 400 2 stroke, green spring for the clutch.
I know that with the pipe, I would need to up the jet size 2 sizes. Does anyone know what the difference in jet size b/ a 400 and a 250 carb is?? I was figureing that I could just put the 400 carb on it and not worry about jetting it.
I know people have done this, I'm just wondering what a start point would be.
Thanks!!
Old 11-16-2011, 04:12 PM
chevy4x494's Avatar
Member #19461
Seriously, a whole Forum for Polaris atv's and NOBODY can give a suggestion???
Old 11-17-2011, 12:27 PM
Member #1958
You need to chek out the Gen3usa.com forum site. There's lots of info on there about what you are trying to do and some really knowledgeable guys working on and running your type machine.
I'd just put the carb on and use a new plug to see how it acts before I started changing jets and tuning in the dark. Once you see how it acts and how the new plug looks you should know about how much and which way you need to go with jets, needle height and air screw.
1999 polaris trailblazer 250 with 400 carb runs sluggish
99 polaris trailblazer 250 carb upgrade
how are the jets sized in a 250 polaris
how to put a 2stroke 400 carb on 250
how to put a polaris 400 carburetor together
polaris 250 400 carb upgrade
polaris 250 carb 400
polaris 250 carb jet size
polaris 250 carburetor mod
polaris 400 carb jet
polaris trailblazer 250 carb jetting 400
polaris trailblazer 250 modification
polaris trailblazer 250 with a 400 carb on it ?
polaris trailblazer carb size
setting up 400 carb on 99 polaris trailblazer 250
sportsman 400 carb trailblazer 250 jet size
trailblazer 250 400 carb
trailblazer 250 carb jets
trailblazer 250 carburetor jets
trailblazer with 400 carb
Adding EBS to sportsman 500? Country Polaris Sportsman 18 09-13-2011 07:33 AM
adding more lights? scroudt ATV General Discussion 3 08-06-2011 04:52 AM
Adding 4th brake back in? riccnick Polaris XP 28 01-27-2011 05:44 AM
Adding Lights and other Trombly ATV Visual & Body Modifications 9 07-17-2010 07:43 AM
Adding headlights to a 50 aapwayneo2001 ATV Visual & Body Modifications 5 04-15-2010 07:51 AM
