11-20-2011, 02:05 PM
Member #11443
2010 500 H.O reverse override mod?
Hey, does anyone know the wires that i need to tape into in order to bypass the override switch in reverse? I tryed using the Grey/orange and the red/white and using the power and ground from 12 volt outlet on the side of the light asssembaly as i found someone posted on the internet. But it didnt work. and when i push the override button it blows the main fuse in the bike. Is it possible to rewire so it automatically engages when put into reverse or is a switch necassary? Thank you in advance!
11-20-2011, 05:39 PM
11-27-2011, 01:10 PM
Member #20142
just tried this on my 2011 500 HO and it works, super easy to do too
Here's the reverse over-ride mod!
Reverse mod- pull the headlight pod off and disconnect the two harnesses going to it. On the big harness locate the gray/orange wire and use a splice connector with another 8" piece of wire and have a female spade end connected to it. Now do the same with the brown(ground) wire coming off the lighter/accessory plug. Hook the two female spades to a toggle switch that you can mount on the pod and you are done. You will have to turn the switch to the "off" position to use the yellow override button to scroll through the different modes or if a young or inexperienced rider is on it for safety.
12-04-2011, 01:34 PM
Member #680
Originally Posted by Thor
Hey Thor, what do these kits entail, are they plug and play or is there splicing involved? Can you post a pic?
Thanks,
Homer
12-04-2011, 01:39 PM
Splicing is involved yes. Sorry no pics.
12-05-2011, 02:57 AM
Member #680
Thanks Thor, guess this is next on my wish list. Don't want to lunch the front diff on accident.
12-05-2011, 06:18 PM
Member #7489
Does it work with the Sramblers?
2004 Predator 500 TL (next in line for rebuild)
2007 Scrambler
2008 Raptor 250 (sons)
2001 400EX (rebuild stage)
12-16-2011, 06:24 AM
Member #20681
Thor, any idea when this will be back in stock? Any idea what shipping is to 75002?
12-16-2011, 01:20 PM
I have one kit left even though is show back order. The kits I have utilize a marine switch to assure they are waterproof. Hey! Looking for A Sportsman Reverse Override kit? Then Click Here! .
2009 polaris 500ho reverse override bypass, 2012 polaris reverse overide bypass, bypass for 2011 polaris 500 ho, bypass reverse on polaris, over ride button bypass 2010 polaris atv, polaris 500 ho reverse, polaris 500 reverse overide 2011, polaris 500 reverse switch, polaris atv override, polaris atv reverse bypass, polaris atv reverse override conversion, polaris atv reverse override switch, polaris override mod, polaris reverse bypass, polaris reverse override, polaris reverse override mod, polaris reverse override switch, polaris sportsman 500 reverse override, polaris sportsman 500 reverse override kit, reverse over ride mod on a 2011 polaris sportsman 500 h.o.
