Old 11-23-2011, 12:34 PM
polarisinnepa's Avatar
Member #19733
do i need a clutch kit??
i have an 09' sporty 500 h.o carbed.. want to step up to 14" rims with 27" tires.. i havent decided what kind yet..but my question is do i need a clutch kit so she runs the way she should?????????????
'09 sportsman 500 H.O
front and rear double tube bumpers
3rd light mod
polaris handguards
uni filter
headlight guards
rear rack extender
front rack extender
2500# winch
nerf bars w/full footwell skid plates
14" polaris wrec rims w/ 26" sedona rip saws
Old 11-23-2011, 01:10 PM
SMP63's Avatar
Member #13545
Some will say yes, some will say no. Depends on the type & style riding you do!!! Trail with a little mud I would say you could get by without one. Mud with a little trail you may want to install one, also depends on the tires you choose to go with. Some are heavier than others. Allot of people go with this rule of thumb that if you go bigger than 2" above the stock tire to go with a clutch kit. I would suggest getting the tires then decide if a clutch kit is needed depending on how the wheeler performs.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 11-23-2011, 01:51 PM
Member #19733
hey smp63.. thanx fr the feedback.. i thought i could get away w/out the kit.. but not sure.. didnt wanna smoke my belt.. i do mostly hardpan but some mud and rock climbin'.. north east pennsylvania can get crzy in the winter..
3rd light mod
polaris handguards
uni filter
headlight guards
rear rack extender
front rack extender
2500# winch
Old 11-23-2011, 02:07 PM
SMP63's Avatar
Member #13545
Read a couple threads here where they have gone up to 29's without clutch kit. I would just wait & see, you can always get one if needed!
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
Old 11-23-2011, 05:07 PM
bgirard420's Avatar
Member #11494
I went with 25" Spartacus and noticed some power loss and increased belt slippage. I added the clutch kit and now I get the front end off the ground in low and can climb much better in high. I think a lot has to do with the weight of the tire. Zillas from what I read here run a little small and are very light so you could probably get away with 27"s, mudlights too. Get a heavier radial (big horns, gbc's ect.) and you might find yourself having to upgrade the clutch IMHO. Good luck!
2010 Sportsman 500 H.O.
Old 11-28-2011, 07:26 AM
lost cause's Avatar
Member #9763
I am one that has run my 800 with 29.5 outlaws with no clutch kit without issues. Just make sure you know when to use low. If you are climbing hills, crawling over rocks, pushing snow, heavy towing, or going through some mud, then use the low gear. Most people that have issues with belt slippage don't know when to use the low gear. Polaris installed one for a reason though. lol.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 12-08-2011, 04:02 PM
eatmydust's Avatar
Member #4838
I have a 07 500 that i put 26" bighorns on, i lost a lot of get up and go with how much they weigh. I still had the same top end but the low end suffered. I put an epi clutch kit on and holy crap is that thing fun to ride now. You will not regret a clutch kit and it isn't hard to do.
2007 Sportsman 500 EFI
12" Motosports Alloys Nukes
26" Bighorns
EPI Clutch Kit
FMF EFI Programmer
Big Gun Evo
Moose Front Spring Preloaders
These Colors Don't RUN
1998 sportsman 500 clutch spring
2011 sportsman 500 clutch kit
aftermarket footwells for polaris quads
do i need a clutch kit on my atv?
do i need a clutch kit polaris
do i need a clutch kit with 26 tires polaris
do i need a clutch kit with 27 tirers 1998 sportsman 500
do i need to do a clutch kit with 27 tires
do you need clutch kit with 26 tires
epi clutch kit for 02 sportsman 500 ho
i have 27' tires on my polaris 500 what clucth kit i need
is polaris clutch kit needed with 26 tires
polaris atv what is required to put on aftermarket can
polaris scrambler 500 clutch kit
when do you need a clutch kit
why do i need a clutch kit polaris atv
why do i need to clutch polaris 500
Clutch or Clutch spring upgrade help!!! eazytony27 Polaris Scrambler 3 04-11-2012 09:55 PM
having clutch problems wonder if its due to big tires or clutch wear HELP johnnypolaris500ho ATV Wheels & Tires 8 04-03-2011 07:17 PM
Primary clutch squeak after installing clutch kit x omerta x Polaris Sportsman 20 08-10-2010 01:46 PM
