Old 11-27-2011, 08:36 PM
Pgmudder's Avatar
Member #20142
Reverse override mod 2011 500 ho
Did this to my 2011 500 HO and it works great. Real easy to do and only took about 20-30 minutes.
Reverse mod- pull the headlight pod off and disconnect the two harnesses going to it. On the big harness locate the gray/orange wire and use a splice connector with another 8" piece of wire and have a female spade end connected to it. Now do the same with the brown(ground) wire coming off the lighter/accessory plug. Hook the two female spades to a toggle switch that you can mount on the pod and you are done. You will have to turn the switch to the "off" position to use the yellow override button to scroll through the different modes or if a young or inexperienced rider is on it for safety.
Old 02-12-2012, 06:13 AM
CapAmerica's Avatar
Member #16284
This sounds a lot easier than the other method of using the dual relays. How has it been working for you? I was thinking there has to be a way to just hard wire the yellow button itself *if you never want to use the factory default 2WD reverse. Your way sounds a little better.
Old 05-10-2012, 05:01 AM
jolliffem's Avatar
Member #25798
Update and Explaination
Pgmudder how has this reverse override mod been working for you? Can you explain to me what you have done in a little more detail? Im curious about what wires you taped into and what the thought pattern was.
Thanks.
Old 05-10-2012, 05:23 AM
highmark's Avatar
Member #9483
We did this as well. Your overriding the PDM with a switch so that you don't have to push the yellow button for full time 4x4 drive in reverse. His instructions above are detailed enough as this is exactly how you have to do it.
We also did this for a fan over ride switch which works the same way but with a different wire configuration.
Old 05-10-2012, 05:33 AM
jolliffem's Avatar
Member #25798
I undestood his instructions I was just wanting to understand the theory behind it. It seems so simple.
I'm also interested in doing the Fan Override aswell. Do you what wires need to be tapped into for this?
Old 05-10-2012, 05:48 AM
highmark's Avatar
Member #9483
Basically the override is to eliminate from having to push the yellow button to engage full 4x4 functionality in reverse.
I found this on another forum with a wiring diagram. You'll tap into the wires from either inside your pod or the wire loam running down the neck of your steering rack.
Help! Polaris reverse override... - ATVConnection.com ATV Enthusiast Community
The fan override is so I can manually manage when the fan turns on and off. We ride in swamps and water a lot so I we didn't want that fan spinning under the water. I'll see if my buddy can post up the exact wiring color for you (born2rescue).
2011 polaris sportsman 500 ho reverse override
2011 polaris sportsman reverse overide
2012 sportsman 500 override mod
2012 sportsman 500 reverse override
code 74 polaris 500 ho
override on polaris 500 sportmans
polaris mods reverse over ride 2011
polaris override button
polaris override mod
polaris reverse overide mod
polaris reverse override mod
polaris sportsman reverse mod
polaris sportsman reverse override mod
reverse override polaris 500
what all does diagnostic mode do on a 2011 polaris sportsman 500 h.o.
what is reverse override atv
yellow on off switch polaris atv
NEW REVERSE OVERRIDE & REVERSE LIGHT MOD!!! no switches and working scroll feature! QuickSilver74 Polaris Sportsman 90 04-19-2012 05:50 PM
NEW REVERSE OVERRIDE & REVERSE LIGHT MOD!!! no switches and working scroll feature! QuickSilver74 Polaris ATV How-Tos 91 02-07-2012 07:52 AM
94 300 Reverse Override GearHd6 ATV Repair and Maintenance 1 10-14-2011 06:21 AM
Reverse override n2mudn ATV Repair and Maintenance 0 07-08-2010 06:43 PM
4x4 reverse override ploughboy ATV Repair and Maintenance 3 02-10-2010 10:36 AM
