Old 12-23-2011, 04:13 AM
mv7's Avatar
mv7 mv7 is offline
Member #21515
snap ring pliers for rear wheel bearings 05 sportsman
so im guessing after bending 3 sets of tips on my snap ring pliers i need to purchase a larger set, the rear wheel retaining ring has some serious spring to it. anyone reconmend a good set
Old 12-23-2011, 06:33 AM
tt425's Avatar
Member #3687
I put a rear wheel bearing on my 2001 Sportsman 400 4x4 about 3 weeks ago a friend helpd me and we used 2 small screwdrivers and placed a rag over the snap ring to keep it from flying thru the shop. If I were to purchase snap ring pliers I would get KD brand part #1715(NAPA service tool is the same thing and same part #).
Old 12-23-2011, 05:33 PM
4getful2's Avatar
Member #1234
The snap rings get rusted and seized ,in the groove,just give it some penetrating oil and a couple taps with a punch, then use snap ring pliers.
atv cv snap ring
best snap ring pliers for wheel bearing
how to get a back wheel bearing out of a polaris 2001 4oo sportman
how to get a slip ring out of a polaris sportsman back wheel
hub bearing snap ring pliers
hub snap ring rusted
kd snap ring pliers
polaris cv joint pliers
polaris sportsman 400 rear bearings
polaris sportsman cv joint snap ring
polaris sportsman rear wheel bearing on cv shaft
polaris sportsman rear wheel bearing slips on cv shaft
polaris sportsman wheel bearings
putting wheel bearings in polaris
rusted snap rings
seized snap ring
siezed snap ring
snap ring plier for wheel bearings
sportsman bearings
wheel bearing snap ring pliers
Rear Wheel Bearings Michael0641 Polaris Sportsman 11 07-29-2011 12:48 PM
Replacing Rear Wheel Bearings? 09wingates Polaris Sportsman 2 06-19-2011 06:40 AM
CV joint inner hub snap ring big idiot ATV Repair and Maintenance 3 03-18-2011 11:24 PM
Rear Wheel Bearings xprider Polaris XP 5 12-23-2010 04:33 PM
Rear boot snap ring-2006 outlaw jamesfaz ATV Repair and Maintenance 0 06-28-2010 09:42 AM
