Old 12-26-2011, 07:24 AM
Barkle's Avatar
Member #20129
Newbie question. Altitude: EFI and clutch mods
Howdy folks!- I don't yet own a Polaris but plan to get a late-model 550 with power steering right after hunting season. I just sold my '03 Honda Rincon to help fund the purchase.
I go to Colorado every summer and routinely ride above 10,000'. (Sometimes as high as 13,000'). Questions: Does a Polaris EFI motor REALLY need any remapping done? Also, I've read a few threads about changing the clutch springs. Are both of these Do-It-Yourself projects? How long do they take to accomplish?
Because my riding in Texas is at 500' to 3,000' I don't want to have to do this stuff unless necessary.
Thanks!
Barkle
Old 12-26-2011, 08:00 AM
Welcome to the board! Should be good to go!
Old 12-26-2011, 03:52 PM
jrp's Avatar
jrp jrp is offline
Member #4745
My summer home is in Colorado at 8200 ft and I ride all summer from 10,000 to 13,000 ft. The EFI has no problem adjusting for the altitude. Whether a clutch kit may help depends more on personal preference, how you ride it, how you load it, how you like the power band to perform, and whether you up-size the stock tires. My first summer in CO with a new 850 XP was all stock and it performed well. Because I'm a big guy and do a lot of slow/rough/steep hill climbing, I did install a clutch kit for the 2nd summer in Co (when I also upgraded the tires). It took me about 2 hours to install the clutch kit (weights & springs). On my 2010 850 XP the hardest part was gaining access to the clutch, which is now under the rear end.
I was happy with the results of the EPI clutch kit for my specific preferences & riding style, but I wouldn't say its needed for everyone just because of the altitude.
I have since changed to a Dalton clutch kit, since its variable weights allow me to more easily change back & forth from 13,000 ft steep/rocky mountain goat trail summer riding, to 3,000 ft winter desert/sand riding conditions.
Jim
'10 850 XP EPS
Old 12-26-2011, 05:08 PM
Barkle's Avatar
Member #20129
Mil gracias, JRP! I am more of a beer-swizzling tourist than a hard-corps MXer when I'm messing around in Colorado. You know, ride 10 minutes, stop, drink a beverage, take some pics, and motor on.
Sounds like the stock EFI will do the job and the clutch will just have to take some relatively minor suffering while I muddle along up there. (If it ain't broke, don't fix it).
Rgds,
Barkle
2000 polaris 500 scrambler clutch problems or altitude
can u just change clutch springs on polaris 850
clutch it on 850 xp instal time
polaris 500 sportsman clutch proper weights for altitude
polaris atv clutch mods
polaris high altitude clutch kit
polaris high altitude clutching
polaris modifications colorado
what do clutch kit have to do with elevation ?
Hepl with clutch setup and carb mods ksscrambler Polaris Scrambler 1 10-05-2011 08:29 PM
05 500 high altitude clutching question Longshank ATV Performance Modifications 1 05-23-2011 08:31 PM
Altitude question rh44mag ATV General Discussion 3 02-02-2011 10:53 AM
clutch mods scrambler1 Polaris Scrambler 1 11-03-2010 06:37 PM
550 XP Hi-Altitude clutch kit nmpolaris Polaris XP 1 05-23-2010 06:19 PM
