Old 12-28-2011, 04:38 AM
stang7tl's Avatar
Member #21650
snorkel help
I have 2001 sportsman 500 4x4 I am building a snorkel. I am going to snorkel the air box, the clutch outlet. now the hole that is on the crank case is what I have a question on. can I cap this? or should I plum it into the air box snorkel? also can someone give a me a breakdown of the vent line and etc that needs to be routed up?
I am also tore on which to use for pluming pvc pipe which is going to be a pain in the ass
or
I see people us pool vacuum hose 1.5" to run to front and ties into the pvc pipe top
Old 01-01-2012, 01:58 PM
Graysen's Avatar
Member #21437
i too am looking to put a snorkel on my atv i have been doing some research and what i have seen most people are using the pool hose mixed with pvc but one thing you need to keep in mind is you should heat tape the crap out of the hole hose because it gets pretty hot in their the vent line not too sure about and the hole in the crank case i have not read anything on that yet sorry i could not help i will let you know if i find anything but other than that let me know how it goes
1999 Polaris Sportsman 500 Remington Special Edition
26" MudWolf's
2" lift kit
UNI filter
1" spacer (front only)
2500lb winch
Old 01-01-2012, 02:00 PM
Graysen's Avatar
Member #21437
How to: 97-04 Polaris Snorkel - MudInMyBlood Forums
26" MudWolf's
2" lift kit
UNI filter
2500lb winch
Old 01-01-2012, 02:02 PM
Jrich96's Avatar
Member #21837
i am also on the snorkel journey.
2009 Polaris Sportsman 500 HO EFI
3 inch puck lift & 1.5 inch spacers
29.5 outlaws (skinny/wide)
Cooler, backrest, ammo cans
Custom stereo
2007 Brute Force NRA edition
30 inch xxl's on ss112 rims
cooler, backrest, ammo cans
custom stereo
2 inch lift & 1.5 inch spacers
MIMB snorkels
Blue parking lights
Full hmf and dynatech optimizer
Old 01-02-2012, 11:38 AM
Graysen's Avatar
Member #21437
did that website help you at all stang?
26" MudWolf's
2" lift kit
UNI filter
2500lb winch
Old 01-03-2012, 05:26 AM
flhunter's Avatar
Member #21045
I can possibly help with pics of mine(was snorked when I bought it) if you need.
I am thinking about going back to stock and wonder of you would consider selling me the vent parts you remove. If so how much shipped to Florida 34984?
Old 01-03-2012, 05:41 AM
stang7tl's Avatar
Member #21650
finished my snorkel the day I used the spa hose but I ran it from under the air box so the seat didn't have a issue closing. I also "T" the intake for the belt/crank with one of my airbox intakes and ran the second air box by its self. I took all my vent lines and ran to my 4th unused stack.
parts wise I don't have the clutch vent it was not on the ATV when bought
http://www.facebook.com/photo.php?fb...type=3&theater
Old 01-03-2012, 06:06 AM
Graysen's Avatar
Member #21437
i hope you sealed everything properly like behind the primary clutch
26" MudWolf's
2" lift kit
UNI filter
2500lb winch
Old 01-03-2012, 09:23 AM
flhunter's Avatar
Member #21045
good job, nice and symetrical. Now just get out the rattlecan and go to town. ps just don't get overspray everywhere like my P.O. did.
Old 01-03-2012, 11:24 AM
Jrich96's Avatar
Member #21837
i like that look i may have to copy that!
Custom stereo
custom stereo
MIMB snorkels
Blue parking lights
2001 polaris sportsman 500 snorkel#gsc.tab
2001 sportsman rear vent hose
500 polaris sportsman clutch vent tube
97-04 polaris snorkel
atv pvc pipes
how to build snorkels for my 1999 polaris sportsman 500
how to make a snorkel for a 1999 sportsman 500
how to remove factory clutch vent tubes on polaris sportman
how to snorkel 97 sportsman 500
how to snorkel a 2001 polaris sportsman
how to snorkel a 97 polaris sportsman 500
polaris 500 vent lines
polaris snorkel kit pipe size
polaris sportsman 500 one 1.5 air snorkel
polaris sportsman snorkel build
polaris vent lines snorkeled
show me how to snorkel my 500 polaris
what size pvc pipe polaris sportsman 500
what size pvc pipe to connect pool vacuum hose
850 xp snorkel kit Boodro Polaris XP 2 10-28-2011 05:53 PM
snorkel your atv Raimey ATV Performance Modifications 4 02-20-2011 05:54 PM
snorkel kit for 00 Mudman420 Polaris Sportsman 2 11-17-2010 04:10 AM
Snorkel Kit ssgtos ATV Parts for Sale 4 09-21-2010 07:57 AM
550 Snorkel Kit? mals_motorman44 ATV New Members 4 09-02-2010 04:49 PM
