Old 12-28-2011, 09:40 AM
jaredk's Avatar
Member #21716
how to remove oil injection from a 94 sportsman
I have a 94 sportsman that I was wanting to take the oil injection off and mix my own, does anyone have any info on this?
Old 12-28-2011, 03:26 PM
Old 12-28-2011, 05:08 PM
vortecz71wv's Avatar
Member #14032
Contact Aaen Performance. They make a block-off plate for this snd will get you going in right direction.
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards (www.TheATVSuperStore.com), 3-High Headlight Mod, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless
Fuel It, Flog It, Feel It!
Old 01-11-2012, 09:08 PM
bmorton's Avatar
Member #22138
easy drain your oiltank and premix your gas. the counter balancer oil will keep the oil pump lubed. Why would you like to stop just pouring oil into the tank tho? thats just sooo much easier.
2 stroke block off plate
94 polaris oil block off
blocking off the oil pump on a polaris atv
how to block off polaris oil injection
how to disable oil injection
how to disconnet the oil mix on polaris 90 2 stroke
oil injection block-off plate
polaris 550 oil injection points
polaris atv oil injection
polaris mod eliminate oil pump
polaris oil injection block off
polaris oil injection removal
polaris remove oil injector
polaris sport oil injection removal
polaris sportsman 90 oil injection removal
polaris sportsman oil pump block-off plate
removing oil injection polaris
sportsman 90 oil block off
sportsman 90 oil pump
95 sportsman oil injection question thomasjkt ATV Repair and Maintenance 1 11-09-2011 05:26 PM
Sportsman 90 Oil Injection? mechanic Polaris Sportsman 0 11-06-2011 12:51 PM
Sportsman 90 Oil Injection Problem onequik1 Polaris Sportsman 3 10-27-2011 12:37 PM
remove or not remove stock A/B snorkel whiplash Polaris XP 3 09-09-2011 07:02 PM
How can I remove the recoil starter from a 94 sportsman monster ATV Repair and Maintenance 5 02-28-2011 03:43 PM
