Radiator relocation will not do anything for your performance. The reason why people relocate their rads is not for looks but for cooling function. If you ride a lot of deep mud the radiator gets clogged up with mud and causes the machine to overheat, so mounting the rad on the rack keeps it out of the mud and also makes it easier to clean if mud does get in it. If you are not having overheating issues then I personally would not relocate it. Doesn't look good and takes up rack space. I relocated mine on my grizz due to overheating issues, but have had no issues so far on my sportsman 800 and I only ride mud.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
