Old 01-08-2012, 06:50 AM
crazyjoe's Avatar
Member #20921
800 vs 850 sound, why so different?
Watching vids on youtube I've noticed that aftermarket exhausts on the 850's sound sooooo much better than the same exhaust on the 800. Is it simply the cam? Would a cam swap in the 800 produce the lower, throatier tone like that of the 850? Or is the 850 just a totally different configuration all together, internals and what-not? The 850's produce an almost muscle car-ish sound, which is what I'm after.
Joe.
Old 01-08-2012, 03:47 PM
crazyjoe's Avatar
Member #20921
Anyone??
2011 Sportsman 800 EFI, bone stock
Old 01-08-2012, 03:54 PM
spellicy's Avatar
Member #19170
With the 850 producing 30ish more HP Id assume it gives the back pressure more room to sound different.
2011 Sportsman 800 efi:
Polaris HD 2500 winch
Polaris front and rear bumper
14" SS212 Rims
27" GBC Spartacus tires
3 headlight mod
2005 phoenix 200:
Old 01-08-2012, 06:09 PM
rickcj7's Avatar
Member #5366
Not 100% sure on this but
Doesn't the 800 engine both pistons move up and down together and the 850 1 is up and the other is down?
[quote]The 850 is not a parallel twin like the 800..it is an inline twin with the pistons 90/270* apart on the crank. That combined with it's firing order make it perform/sound much like a V-twin. It makes the 800 seem like it should be in a tractor. The 850 has to be the smoothest ATV engine I have ever ridden and it has nice power delivery and gets better mileage than the Polaris 800.[quote]
07 500 X2
all the goodies
SOLD
09 550 XP EPS
Lock n Ride boxes
Warn Provantage
Warn XT2500
Guru bumpers
Meade Rock sliders
hot grips
Acerbis guards
Montana GPS
Old 01-08-2012, 06:50 PM
crazyjoe's Avatar
Member #20921
That would make sense then as to why it resembles more of a deep V-twin sound. I bet even a healthy cam wouldnt produce the same type of sound as the 850 (although it would have to sound better than stock).
Old 01-09-2012, 12:14 PM
Monkey Man's Avatar
Member #12591
Send a message via ICQ to Monkey Man Send a message via Yahoo to Monkey Man
I thought? that all Polaris Twin engines had the 2 pistons travelling in mechanical phase but 180 degrees out of phase so while both pistons are say in the upward stroke one will be in the compression stroke while the other will be in the exhaust stroke. This gives good power and smooth torque, tis easy to check anyhow, remove your plugs on your XP, rotate the engine with the starter until one of the cylinders is on Top dead centre and simply measure the depth using a plastic rod (drinking straw, knitting needle etc. but engine needs to be cold for this) then measure the second cylinder depth. If both are the same depth then the pistons are in mechanical phase, if it's the depths are different then they are out of mechanical phase (I would guess 180 degrees).
Regards - MM
It's Trail Time!!!
Old 01-10-2012, 11:49 AM
bakada's Avatar
Member #2821
I have the same exhaust on both my 500 and 700. The 500 has a deep throaty thump like a big single should have. My 700 is higher pitched and sounds more like a tuner. I have always wondered why. My buddy has the same Big gun exhaust on his v twin brute force and it sounds like a Harley.
Old 01-15-2012, 12:46 PM
PolarMud's Avatar
Member #628
800 is old school "Overhead valve" technology. Whereas the 850 is Single Overhead Cam.
06 Sportsman 500efi LE. 26" Big Horns, ITP ss212, QSC clutch, Muzzy full exhaust w/ Big Gun TFI
09 Mossy Oak RZR w/ 26" Bajacross, Big Gun exhaust and a bunch of other junk
10 Can Am Renegade 800R Muzzy pipe, Dobeck, Precision Steering Stabilizer and anti vibe mounts, Grim Reapers, Twin Air, graphics kit, Elka stage 1
2010 sportsman 800 efi tuner
2012 sportsman 800 parallel twin?
850 polaris firing order
850 sportsman secondary tas-03 clutch
big gun efi tunner 850 sportsman
can am 800 fireing order
canam big gun efi tuner
is the 800 sportsman engine a v twin
is the polaris 850 sportsman a v twin engine or a inline twin
muzzy's sportsman 800
neden polaris 850
polaris 800 atv engine firing order
polaris 800 firing order
polaris 800 v twin
polaris 800 vs 800 ho
polaris 800 vs 850
polaris 800 vs 850 engine
polaris atv engines twin v/s
sportsman 800 vs 850
what's different about the polaris 850
how does this sound rkpalm ATV Purchasing and Price 2 12-19-2010 04:50 AM
clicking sound bird barrel ATV Repair and Maintenance 2 10-08-2010 10:18 AM
This May Sound A Bit Strange.... dl_craftsman ATV Repair and Maintenance 3 09-22-2010 11:15 AM
sound InkedAdrenaline Polaris Outlaw 3 09-08-2010 03:47 PM
Clunking sound????? chopperdude ATV Repair and Maintenance 3 07-02-2010 08:10 PM
