01-17-2012, 06:31 AM
Member #12019
Lift Kit ??
I have a 2011 Sportsman 800efi and I have a question concerning lift kits. I'm thinking about installing this kit, Polaris Sportsman Lift Kit 500 600 700 800: 1999-2011 | eBay and my question is....
If I add this lift kit to my machine, will I have any premature wear to "U-joints" or any other part????
I don't ride hard or do much tearing around on it. I use it for plowing snow, getting back and forth to the lake icefishing, a 25 mile round trip. I may pull a disc around for a food plot during the summer but, its not that large. I've most likely purchased my last machine (according to the wife) and we both would prefer it to last. However, becasuse of the Glacier III plow wear bar, which I already have to replace this week after just a couple uses, I'm going with a thicker and also wider wear bar. A 2" lift would keep me within my current raised height.
Thus the question.....
01-17-2012, 08:22 AM
Member #9763
With the lift kits on the 2011 you will need to also purchase the rear axle bar kit from higlifter, or gorilla axles. The stock rear axles do not work with a lift on the 2011 model. As far as premature wear, anytime you increase the angle of the axles you also increase the chances of breaking one. That being said, as long as you are carefull with the throttle, and just get pulled out when stuck, the axles should last just fine.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
01-17-2012, 09:29 AM
Member #12019
Thank you... I guess I'm just going to get buy with what I have. I don't run it hard but, thought it might help get the plow higher.
01-17-2012, 09:46 AM
Member #9763
you could put a 2 inch spacer under the front spring or get HD springs. That would help if you don't already have that.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
01-17-2012, 09:57 AM
Member #3694
the HD springs would help, or you can hillbilly rig it. I just bought 2 hockey pucks, cut out holes big enough to fit around the struts, and put them under then springs. I gained a little clearance but my springs are stiffer and won't drop as far.
01-17-2012, 11:14 AM
Member #3001
I would go with the HD springs , they raised my 09 HO 2 1/2 inches in the front ! It gives it a much a meaner look ! $50.99
Greg Smith
2009 Sportsman 500 HO
Glacier II Plow , Warn 3000 winch , winch saver
Rear grab bar , Polaris hand guards, HD Springs
Front rack extender , ATV Guru Brush guard
12X7 ITP Delta wheels, 27X9X12(F) 27X12X12(R)Mud Lite XL
Nerf Bars from Outlaw Fabrications , Maier fender flares
1996 Trailboss 250
01-17-2012, 12:52 PM
Member #20681
The "moose pregressor" adjustable spring inserts are also an option. I just installed them on my 500HO and it lifted the front some. Basically increases spring preload by 1".
2012 Sportsman 500, Red.
02-21-2012, 02:39 PM
Member #18814
Were did you get those fender flares? also were did you order your HD springs from? are they for the front and back or just the back?
looks mean for sure!
02-21-2012, 02:47 PM
Member #15054
is 2011 a different axel design than that of a 2009, I too is thinking of putting on a 2" lift on my 09 800, most say with 26" tires I'll be alright with my stock axels.
02-21-2012, 03:20 PM
Member #3001
The fender flares came off ebay from allsportperformanceinc
The HD springs came from Honda East Toledo , a supporting vendor on this site. I just installed them on the front , helps with the extra weight of the snow plow!
Greg Smith
1996 Trailboss 250
2009 sportsman 800 h.o. rubber down customs 2 lift epi hd springs 29.5 s/w outlaws on itp ss312 1.5 spacers gorilla rear, do i have to replace the struts on my trailblazer if i lift it 2 inches, ebay atv lift kits/polaris, high lifter lift kits polaris, how to install rear lift kit on polaris, lift kit, lift kit for a polaris 2006 sportsman 800, polaris lift kit forom, putting a lift kit on a polaris atv
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
lift kit
xxlsutigersxx |
Polaris XP |
5 |
10-07-2011 08:21 PM |
will i need a lift....
solid_crimson |
ATV Wheels & Tires |
2 |
03-24-2011 05:44 AM |
lift
natelong |
ATV General Discussion |
4 |
01-08-2011 09:23 AM |
RDC lift?
409scrambler4x4 |
Polaris Scrambler |
1 |
05-08-2010 03:21 AM |
09 500 lift?
jps37033 |
Polaris Sportsman |
0 |
05-05-2010 06:05 PM |
