how far do you want to go with it
moose,dyna,and a couple others make carb jet kits,kliehn them selves make a fuel/mixture screw<way move precise>on adjustments,and two more fuel meetering valve,and they are fully adjustable for zero tolerance in full throttle hesitation,then change ur air intake box,the filter,a monster coil,hot ignition cdi box,beyond in head work<port,polish,over sized valves,5 mil drop in crank from ktm,hot seat big bore kit,tricked out clutch basket-exctra>you options are unlimited.all depends on your dollar alotment?10,000.00,20,000.00 or more!!!!!!!!!!!!!11
 in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outhere  pilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiers  not here
