Old 01-19-2012, 08:07 PM
fultons's Avatar
Member #17399
2011 800 cold weather starts
I have purchased a plow for my 11 800 however it has been around zero the last couple days and when I try to start it to plow the drive, it will not even turn over the engine. It sounds as if the starter engages but will not turn the engine over at all, is this a due to the small battery not having enough cold cranking amps or is my battery shot, or do I need to get a block heater to keep the engine warm enough to start?
Old 01-20-2012, 05:14 AM
options89's Avatar
Member #21904
I would try charging the battery first to see if thats the issue, if that doesn't work I would say your battery is shot. My 2012 has been outside for the past couple of days and she still fires up fine.
Old 01-20-2012, 03:20 PM
Old 01-20-2012, 09:21 PM
800touring's Avatar
Member #14149
my 800 fired up under 2 feet of snow and 4 below zero
Old 01-21-2012, 02:13 AM
bp405's Avatar
Member #18562
did a little battery research on here a couple of months ago and these batteries are hit n miss. if u say u hear the bendix engaging and the starter not turning my first attack would be the the battery. try charging it.
2011 sportsman 800 efi
polaris front brush guard
polaris rear brush guard
polaris front lock n ride cargo box
polaris rear rack extender
warn RT 3.0 winch
polaris front spring adjusters
ricochet a-arm guards
ricochet full frame skid plate
itp T-7 beadlock 14"
maxxis big horn 2.0 26x9 front
maxxis big horn 2.0 26x11 rear
QSC clutch kit
Old 01-21-2012, 03:57 PM
bakada's Avatar
Member #2821
Put a battery tender on it and always keep it plugged in when it is parked and especially when it is cold. Ive got ATV batteries that have been going strong for over 10 years that are always plugged in when they are parked.
Old 01-21-2012, 04:28 PM
wolverine22's Avatar
Member #15541
yeah i hear that a lot from people that plow. Your winch uses a lot of power its a good idea to put it on a battery charger after your done plowing. -30 here and still starting like its summer
Old 01-21-2012, 04:55 PM
bakada's Avatar
Member #2821
Thats a good point but there is more involved. I had an Interstate battery guy tell me that these little power sport batteries do not like to sit. It doesn't take much for them to loose there charge when they are not used and then plates short and the battery is toast. He said if you are going to leave it sitting for more than a few days to plug it into a tender. He told me that if they drop to less than 12 volts they run the risk of freezing when it gets cold and then there toast. If you keep them plugged in all the time then they are always ready to go and during the winter they will always be at 13 or more volts that way they will never freeze. I have had batteries that I have left sitting all winter plugged in at temperatures nearing 50 below and they fired right off come spring. As mentioned in my previous post I have batteries that are over 10 years old that are still going strong. It took me complaining to the Interstate guy about having to put a new battery in my ATV and snow machines every 2 years before I finally received an education on Small Battery 101. Battery tenders are at the heart of keeping a power sport battery going. I have dedicated 2 prong plugs on the sides of all my machines that I just plug the tender right into when I park them. They have short heavy guage wires run right to the batteries and they make a great power port for getting juice for inverters or 12 volt pumps.
Old 01-21-2012, 06:22 PM
WIscrambler's Avatar
Member #17647
I'm having the same problem with my 2011 800. I had to use jumper cables on it this morning when it was 10 degrees outside. After plowing and using the winch for an hour, I shut the machine off. I immediately tried to restart the machine, and the battery was too weak. Did I mention I bought the machine new 4 months ago? I have an appointment at the local Polaris dealer on Tuesday to have it looked at under warranty.
2011 Sportsman 800 EFI
Superwinch Terra 35
Polaris HD front springs
KFI 60" Pro-Series plow
ITP SS212 wheels
25" GBC Grim Reaper tires
Old 01-21-2012, 06:27 PM
bakada's Avatar
Member #2821
The battery is still probably 2 years old. Let them replace it under warranty but put a battery tender on it especially in the winter and it will last years longer.
2011 polaris 800 not starting
2011 polaris sportsman 800 battery
2011 polaris sportsman 800 battery issues
2011800 polaris utv
atv for cold temps
atv in cold weather
best cold weather starting utv polaris
cold temperature sportsman 800 efi starting
cold weather atv start
heavy duty polaris 800 battery
how to get your atv to start in the cold
interstate batteries 2011 polaris
my atv will not start cold weather
polaris atv doesn't start when cold weather
polaris sportsman 500 efi cold weather starting
powered by vbulletin interstate batteries
powered by vbulletin weather
starting your atv in cold weather
what to do if your atv has a cold start
what to do if your atv has been in the cold for days
1990 Polaris Trailboss 350 4x4 Running Issues... Carb? Cold Weather?? JBuckley ATV Repair and Maintenance 15 04-06-2012 07:46 PM
Cold weather 700 starts? The700Dude Polaris Sportsman 15 01-19-2012 06:24 PM
2001 Scrambler 50 Cold Weather Problems wolfmt Polaris Scrambler 14 01-17-2012 09:10 PM
can cold weather deflate a tire? Scott6by ATV Wheels & Tires 12 12-22-2010 05:25 PM
Cold weather starts Birdfish ATV New Members 4 01-08-2010 07:43 AM
