  #11 (permalink)
Old 01-30-2012, 01:51 PM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
You don't tie knots in synthetic. The knot becomes a very weak point in the rope. Google "Splicing 12-strand synthetic". Most synthetic winch ropes come with an eye already spliced at one end. As for the rubber winch savers I just drilled a hole in an old golf ball and threaded the rope through it. Cheap and works like a charm.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
  #12 (permalink)
Old 01-30-2012, 02:00 PM
Smoothbassman's Avatar
Member #2920
Originally Posted by gregv92c View Post
Just got some synthetic rope and was wondering how to you put the hook on ? Do you tie a knot? wrap around and tape it ? Just wondering ?
12 strand eye splice. Super easy to do. Search it on the forum. I did a walk thru on it a year or so ago.
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
  #13 (permalink)
Old 01-30-2012, 02:37 PM
stroker2011's Avatar
Member #13796
You go to search and look up synthetic rope, there was a link someone posted on how to tie hooks onto synthetic rope, i remember looking at it recently. I think it comes down to the type of knot that needs to be tied. For the thimble, you’re going to have to get a bigger one or get a chain connector. I believe there called safety chain quick links. (it looks like a link of chain that opens and spins shut) to attach your hook. I went with Warrior too.
  #14 (permalink)
Old 01-30-2012, 02:49 PM
gregv92c's Avatar
Member #3001
Originally Posted by SMP63 View Post
I ordered mine from warrico. They come with a thimbal in 1 end. If my hook from the cable is too small to go over it I plan on getting a small shackel for it.
I also got mine from Warrico . One end is terminal and the other end has a small piece of tape on it . I was told the terminal end was to mount the line to the winch if needed , if I don't need it to cut it off. But I see no thimble !
Greg Smith
2009 Sportsman 500 HO
Glacier II Plow , Warn 3000 winch , winch saver
Rear grab bar , Polaris hand guards, HD Springs
Front rack extender , ATV Guru Brush guard
12X7 ITP Delta wheels, 27X9X12(F) 27X12X12(R)Mud Lite XL
Nerf Bars from Outlaw Fabrications , Maier fender flares
1996 Trailboss 250
  #15 (permalink)
Old 01-30-2012, 05:21 PM
SMP63's Avatar
Member #13545
Got the rope in the mail today. Mine has the thimble in it & looks very stout. I like the way they put heat shrink around the spiced end. Well done Warriorco!! Gregv get in touch with them & find out why
it doesn't have one. It'll make attaching the hook allot easier!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
  #16 (permalink)
Old 01-30-2012, 05:42 PM
Lawdog's Avatar
Member #16413
My plow line is from Warriorco too. Here's what it should look like. I've also thrown in a picture of a terminal end for comparison.
Phil said most winches will NOT need the terminal end. My Polaris 2500# did not. I just pushed the taped end into the small hole with a Torx head screwdriver and once it was in place, slowly wrapped it as the winch pulled it in.
The only issue I had was the thimble was so stout that the winch hook was too small to fit over it. So, I am using a carabiner to hold the plow until I can buy a bigger hook/shackle. I hope this helps.
Mine: 2009 Polaris Sportsman 550 XP EFI Stealth
Hers: 2007 Sportsman 500 H.O. EFI Sunset Red Limited Edition
  #17 (permalink)
Old 01-30-2012, 05:59 PM
SMP63's Avatar
Member #13545
Good pics Lawdog!!! I'm gonna go the shackle route to attach the hook. I think they are stronger than the quick links. The carabiner was a good idea for hooking it to the plow!!!!!!!!!
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
  #18 (permalink)
Old 01-30-2012, 06:01 PM
gregv92c's Avatar
Member #3001
Mine has the big loop on it , it must be the small end(terminal end) I ordered that I didn't get . I checked the terminal end option when I ordered , he said if I didn't need it I could cut it off . In some of the other threads the pictures don't look like they have the stainless steel thimble on the end of there cable with the winch saver !
Greg Smith
1996 Trailboss 250
  #19 (permalink)
Old 02-01-2012, 01:00 PM
SMP63's Avatar
Member #13545
Good to hear gregv!!! Installation was quick & easy, had no burs on flare head or drum. Best of all the hook fit over the thimble!!!!! Thanks again Warriorco!!!!!!!!
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
  #20 (permalink)
Old 02-01-2012, 01:59 PM
gregv92c's Avatar
Member #3001
I just installed my winch saver on my steel cable, it has only been used a couple times to plow snow with . I'll just keep my synthetic rope for a spare .
Greg Smith
1996 Trailboss 250
12 aluminum fairlead
attaching hook to synthetic rope for winch
atv fairlead for synthetic rope
atv synthetic 12' snow plow rope
atv synthetic rope repairs
atv synthetic winch cable spokane
atv warn fairlead synthetic rope
how many feet of rope goes on a polaris winch
how to put a hook on a synthetic rope
how to tie a knot on the end of a synthetic winch cable
polaris synthetic rope
polaris synthetic winch rope
polaris winch syntheric fairlead
polaris winch synthetic rope
polaris winch, using rope instead of cable for snow plow
synthetic cable fairlead
terminal end installation on synthetic rope
terminals ropes sinthetic
tying a good knot with sythetic rope on a fourwheeler
warn polaris rope fairlead
Synthetic Rope and Winchsaver JimT Polaris Sportsman 15 01-17-2012 11:03 PM
Synthetic Winch Rope IndyRed800 ATV Repair and Maintenance 10 12-06-2011 02:38 PM
Synthetic winch rope repair????? Frozen6bt ATV Repair and Maintenance 18 02-25-2011 04:56 AM
Synthetic rope for winch sparky Polaris Sportsman 3 04-24-2010 03:43 PM
Synthetic rope polarisfamily ATV General Discussion 1 10-22-2009 06:59 AM
