Old 01-21-2012, 07:44 PM
stroker2011's Avatar
Member #13796
Synthetic rope set up.. fairlead help???
Right now I have a cable winch set up and it needs to go. It just broke on me tonight while plowing and I'm bout sick of dealing with it. So, synthetic I go. My question is about the fairleads, is the hawse fairlead or the UHMW roller fairlead the way to go???
Only thing I’ve read is the UHMW can bind with snow and ice and could cause problems. And some guys don't like the idea of the rope rubbing on a solid piece of aluminum (hawse).
My primary use at the moment is plowing, but I use it when I am stuck too.
I plan on running a shorter rope (12 foot) for plowing and 50 for summer months with a winch saver on it.
I have not purchase anything yet so,
Any suggestions or direction would be appreciated.
Thanks,
Guys
Old 01-21-2012, 07:59 PM
Old 01-21-2012, 08:14 PM
Educ8r's Avatar
Member #7168
I installed a synthetic rope over a year ago with an aluminum fairlead. I run a 12ft winch rope in the winter for plowing and change over to a 50ft rope for the rest of the year. So far the fairlead has performed flawlessly.
Old 01-21-2012, 08:31 PM
Member #13796
I figured if im installing the synthetic, i might as well install the new fairlead too, due to the cable burring the oringial one all up..
educ8r-So, you did the basic aluminum fairlead with the rollers??? Or the solid one?
thanks
Old 01-21-2012, 11:18 PM
Lawdog's Avatar
Member #16413
I just bought a hawse for my switch to synthetic. They can be had cheap many places... $20 or so...
I will install it tomorrow with a 12 ft plow line. Make sure it's rolled on the edges where it will touch rope.
Mine: 2009 Polaris Sportsman 550 XP EFI Stealth
Hers: 2007 Sportsman 500 H.O. EFI Sunset Red Limited Edition
Old 01-22-2012, 06:54 AM
Educ8r's Avatar
Member #7168
thanks
The solid aluminum. Get one of those rubber winch savers to put on the line to help protect the fairlead. Good luck.
Old 01-22-2012, 07:46 AM
shep's Avatar
Member #20739
I gotthe one with the "plastic rollers" it was only a few more bucks then the solid one
2011 sportsman 550 EFI
-heated grips
-polaris 2500# winch
-AcerBis uniko atv handguards
-moose 48" plow
Old 01-22-2012, 08:32 AM
rickcj7's Avatar
Member #5366
The solid fairlead is so the rope doesn't get caught between the rollers and damaged.
07 500 X2
all the goodies
SOLD
09 550 XP EPS
Lock n Ride boxes
Warn Provantage
Warn XT2500
Guru bumpers
Meade Rock sliders
hot grips
Acerbis guards
Montana GPS
Old 01-30-2012, 09:35 AM
gregv92c's Avatar
Member #3001
Just got some synthetic rope and was wondering how to you put the hook on ? Do you tie a knot? wrap around and tape it ? Just wondering ?
Greg Smith
2009 Sportsman 500 HO
Glacier II Plow , Warn 3000 winch , winch saver
Rear grab bar , Polaris hand guards, HD Springs
Front rack extender , ATV Guru Brush guard
12X7 ITP Delta wheels, 27X9X12(F) 27X12X12(R)Mud Lite XL
Nerf Bars from Outlaw Fabrications , Maier fender flares
1996 Trailboss 250
Old 01-30-2012, 01:35 PM
SMP63's Avatar
Member #13545
I ordered mine from warrico. They come with a thimbal in 1 end. If my hook from the cable is too small to go over it I plan on getting a small shackel for it.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
12 aluminum fairlead
attaching hook to synthetic rope for winch
atv fairlead for synthetic rope
atv synthetic 12' snow plow rope
atv synthetic rope repairs
atv synthetic winch cable spokane
atv warn fairlead synthetic rope
how many feet of rope goes on a polaris winch
how to put a hook on a synthetic rope
how to tie a knot on the end of a synthetic winch cable
polaris synthetic rope
polaris synthetic winch rope
polaris winch syntheric fairlead
polaris winch synthetic rope
polaris winch, using rope instead of cable for snow plow
synthetic cable fairlead
terminal end installation on synthetic rope
terminals ropes sinthetic
tying a good knot with sythetic rope on a fourwheeler
warn polaris rope fairlead
Synthetic Rope and Winchsaver JimT Polaris Sportsman 15 01-17-2012 11:03 PM
Synthetic Winch Rope IndyRed800 ATV Repair and Maintenance 10 12-06-2011 02:38 PM
Synthetic winch rope repair????? Frozen6bt ATV Repair and Maintenance 18 02-25-2011 04:56 AM
Synthetic rope for winch sparky Polaris Sportsman 3 04-24-2010 03:43 PM
Synthetic rope polarisfamily ATV General Discussion 1 10-22-2009 06:59 AM
