01-23-2012, 12:25 PM
Member #22600
Aftermarket CDI
Hey guys, just found this site the other day and would like to say it's pretty awesome. I have a 2011 Sportsman 500 HO and I want to get all the performance I can out of it. I have ordered a Big Gun Evo full exhaust and jet kit, I have already changed the air filter. I plan on getting a better spark plug once the other parts come in.
My question is are there any aftermarket performance CDI boxes out there that would be applicable to my bike? And also I am open to any opinions and suggestions on how to get the most outta my 500.
01-23-2012, 01:44 PM
01-23-2012, 02:06 PM
Member #20465
As far as I know there are no manufactures of aftermarket CDI's for 500. The fuel injected engines are a whole different story. With fuel injection there are a ton of parameters to play with. On a model with a carburetor there is little to no performance be gained from a CDI box. If a timing advance is what you after you can grind slots into the pulser coil and advance it at the flywheel. I did this on my street bike and noticed a very slight improvement. It was hardly worth the effort.
Cheers.
01-23-2012, 05:01 PM
Member #22600
Thanks for the replies fellas. Well, like I said before I am open to any suggestions for improvements to my Sportsman 500.
02-16-2012, 08:45 PM
Member #23274
I went on E bay to find a CDI for my '96 300. All the stock boxes were over 400.00 ,but there were some aftermarket boxes that had better timing built in plus a rev limiter delete!! What a change!!!! Plus it was only $185.00 with a 3 yr. warrenty!!!
02-17-2012, 08:24 PM
Member #23274
Go to ebay, punch in your info, and parts show up'. I found one on there just a little while ago called RICK'S HOT BOX. Mine made a BIG difference! Just gotta dig.
02-19-2012, 08:12 AM
Member #22600
I've tried ebay and found nothing other than stock, also Rick's website has none for a 2011 Sportsman 500 HO. Thanks for the trying though.
2011 Sportsman 500HO
-Big Gun Evo Utility full exhaust system
-K&N oil and air
-Stage 1 Dynajet Kit
-NGK Plug & Race Cable
2012 Sportsman 500 HO Orange Madness LE
-2500lbs Warn Winch
02-19-2012, 11:40 AM
Member #23274
I'd contact him and ask if they got anything in the works for yours.You never know!
02-19-2012, 03:21 PM
Member #22600
true....
-K&N oil and air
-2500lbs Warn Winch
02-21-2012, 04:44 PM
Member #23274
Also, look at the header on here. Dyna-tec is a product I have used when working on bikes. Some place else to look bud.
after market polaris cdi, aftermarket atv cdi performance, aftermarket cdi, atv aftermarket cdi, big evo utility exhaust 500 ho, performance sportsman 500 cdi box, polaris cdi aftermarket, polaris performance cdi, sportsman 500 alba cdi
