Old 02-06-2012, 07:50 PM
dgsmooth's Avatar
Member #13603
4-stroke jetting basics
howdy all - i just got a 2003 scrambler 500, just going through it and wantto make sure its running as good as it can be. it seems to run ok but seems a little low on power and back-fires bit... it has a white bros slip on on it, and it will have a better filter right away. i guess i'm wondering if the jetting should be stock with only a slip on and filter, or should jets and needle all be a little richer? how do i know when i have it perfect?
Old 02-07-2012, 03:51 AM
Member #1958
You'll probably need to be a little richer. You have to read the spark plug through trial and error testing. Make sure to start with a fresh/new plug. There is plenty of info on reading plugs available with a Google search and I think there may be a sticky post on this forum you can pull up with a search.
jetting a 500cc four
Scrambler 400cc 2 stroke or 500cc 4 stroke dsbummy Polaris Scrambler 11 05-12-2012 04:50 AM
Jetting an 05 Mclark Polaris Predator 5 01-20-2012 04:21 PM
two stroke to four stroke conversion! xplorer55 ATV Performance Modifications 20 01-11-2011 09:13 PM
2 stroke to 4 stroke engine swap? dstewart Around The Garage 4 12-26-2010 12:05 PM
