Old 02-08-2012, 05:15 PM
SETXwheeler's Avatar
Member #22658
Need clutch kit help!?
I have a 1994 polaris xplorer 300 and I can't seem to find a clutch kit that is the right motor size or year model. Could I maybe use one that is maybe a little bigger motor size or a couple years newer?
Thanks, Drake
Old 02-08-2012, 07:04 PM
Ricko's Avatar
Member #22928
I haved same issue for my 1992 trailboss 350L, so i founded one from a polaris snowmobile 340, i just have to cut ring gear anchors.
Old 02-15-2012, 12:27 PM
QUADSHOP GUY's Avatar
Member #7354
some of the smaller engine machines we always just do a custom grind on the weights to make them shift at the correct rpm. we dont offer kits for some of the smaller/older/uncommon machines but we can custom make them.
#99 HIGH LIFTER/POLARIS RACING.
QuadShop Customs.com
Old 02-16-2012, 01:30 PM
Member #22658
You don't think like maybe a 1996 xplorer 300 will fit my 1994 xplorer 300?
Old 02-16-2012, 07:58 PM
RENOBADBOY's Avatar
Member #23274
I have a '96 Xplorer 300 and I've been talking to EPI about their kit for my quad,but they don't want to give out any info. Well, I took mine apart today to find out why it wasn't working. My driven(rear) clutch came off in pieces!! There's a C-clip in the back that holds it all together that was broken. The good thing was it all came apart easy. So I can see how it operates. There's several holes to put the spring into to stiffen it up.I'm just gonna check if there's a stiffer spring to replace the messed up one and get some heaver weights for the drive(front) clutch. I went with 1" larger tires. Alot cheaper than $250.00!!!!
Old 02-18-2012, 08:17 AM
RENOBADBOY's Avatar
Member #23274
I just spent a few hours with CVT CLUTCHING 101. In addition to heaver weights I'll be looking for a heavier spring for the drive clutch as well. I'm looking to lock up faster and harder. As I said before, I'm more into "crawling" not speed.
Old 02-20-2012, 05:03 PM
Member #22658
well i've found out mine is a '96 and I'm wanting to be able to add some larger time to do a little mudding
Old 02-20-2012, 06:27 PM
lost cause's Avatar
Member #9763
Call quadshop customs, they will be able to help you out with what you need.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 02-20-2012, 08:32 PM
RENOBADBOY's Avatar
Member #23274
Mine's a '96 Xplorer 300. I'd be hesitant to try mudding the smaller quads. I had to go across a small river with mine and just barely made it. It took 45 min. for the clutch to dry out. By the way, I've added 1" taller tires on mine. I'm getting ready to do some clutch mods on mine after reading the CVT article on here.
Old 02-21-2012, 07:46 AM
Member #22658
Im not talking about going through be hole but if i need to go through one i want to be able to, I also plan on snorkelin every thing(air, clutch ,etc.) I also plan putting skinnies on the back and going up about 2 sizes on the front.
performance clutch kit polaris xplorer
powered by vbulletin 340 polaris snowmobile
powered by vbulletin polaris snowmobile clutch
Clutch or Clutch spring upgrade help!!! eazytony27 Polaris Scrambler 3 04-11-2012 09:55 PM
Whats the difference between a 4x4 clutch an a 2x4 clutch scrambler1 Polaris Scrambler 2 01-16-2012 08:45 PM
93 350L Drive Clutch and Driven Clutch Removal dpherll ATV General Discussion 1 11-24-2011 06:05 AM
having clutch problems wonder if its due to big tires or clutch wear HELP johnnypolaris500ho ATV Wheels & Tires 8 04-03-2011 07:17 PM
Primary clutch squeak after installing clutch kit x omerta x Polaris Sportsman 20 08-10-2010 01:46 PM
