Old 03-03-2010, 04:43 PM
realdeal850's Avatar
Member #3456
suggestions for my 2009 850 xp
hi everyone..i bought a new 2009 850 xp eps last year.its got 118 miles on it now.just want some ideas for more power.i put a k&n filter in it.other then that it is completely stock.been thinkin of a power commander or something along this line.has anyone got one of these?if so was there a noticeable power difference?possibly a exhaust too?any help would be greatly appreciated.thnaks again
Old 03-03-2010, 04:56 PM
welcome! how do you like your XP so far?
a power commander isnt going to help you at all unless you do airbox mods(more then just a K&N filter) and a full performance exhaust system. actually it will probably make it slower and run like crap because all it does is piggy back on FI system and change the signal before it gets to the injectors. it allows you to control how much fuel the injectors are going to push through. but stock you dont need more fuel through the injectors, itll make it too rich.
probably the best thing to do is to get a clutch kit, exhaust, and then maybe a power commander, depending on the exhaust.
or you could check out these guys. they have a speed kit already set up for you....and awesome customer service. if you get in touch with them, they will get you all set up and do all the leg work for you
Old 03-03-2010, 05:32 PM
cam101311's Avatar
Member #2311
Send a message via Yahoo to cam101311
welcome to the site
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
Old 03-03-2010, 06:33 PM
*moved thread to performance and modification section. although we most definitely welcome you here, and it is your first post and introduction, i believe given the nature of this thread more people in the future with a similar question will have an easier time finding it here.
...and to clarify the exhaust thing. if you get just a slip on, you probably dont need a power commander as the EFI should be able to compensate for the difference, if you get a full exhaust, then you will absolutely want a power commander. and..... if you go with a set up that needs a power commander, make sure to mount it in a convient location so you can fine tune the FI system while on the trail. somewhere like under the seat or front or rear storage box.
if your not concerned with noise, exhaust for sure!
Old 03-04-2010, 03:29 AM
SNW629's Avatar
Member #1414
you will see no gains from just a slipon pipe,just better sound.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
Old 03-04-2010, 03:46 PM
Member #3456
thanks for the advice.i think i will go with a clutch kit first...not real sure how this will effect the performance??blueline i really like the 850 so far.its has alot of power i think.i have alot of friends that have 750 brute force and they say that they have more power and speed.so i wanna get all that i can get from my 850.if anyone has any advice on what brand of clutch kit that would help too..thanks again for all of your input
Old 03-05-2010, 03:25 AM
SNW629's Avatar
Member #1414
dalton clutch kit. read my thread about it here.
09 850XP EPS
Old 03-05-2010, 02:17 PM
Member #3456
snw629 i read your thread.i dont plan on changing tire size anytime soon..so if i read your info correctly it would not be a good idea for a clutch kit?if this is correct please let me know of any other mods i can make for better performance?thnaks for the help
Old 03-05-2010, 07:00 PM
denseleit's Avatar
Member #2441
Let it brake in a little more too. I noticed mine is really started to making more power around 500 miles or so..
2009 Sportsman XP 850 W/30" ZILLA'S, Team industries 14% gear reduction kit & high altitude clutch kit,3.5 degree advance key,heated grips,superwinch terra 4500,.
2011 RZR w/28" Zilla's, superatv springs, seatbelts and bunch of goodies.
2002 33' Tahoe toy hauler
2008 F350 FX4 crew cab diesel,spartan tuned,S&B,4" back.
Old 03-06-2010, 03:40 AM
SNW629's Avatar
Member #1414
realdeal
the stock clutching of the 850 is very good for stock tires,if you did the clutch kit it will give you a better hole shot just from the higher engagement rpm but do not look for a huge gain. the 850xp is what it is,a big,heavy trail quad. if you could shave a 100lbs off it and install a pipe and a power commander with a dyno tune and the clutch kit then you would notice a change.
09 850XP EPS
2010 polaris xp license plate kit
850 xp power parts
modified 850 xp exhaust
modified exhaust for 850 xp
more power out of 09 xp 850
performance upgrades for 850 xp eps
polaris 850 atv aftermarket bushings
polaris 850 performance parts
polaris 850 xp license plate bracket
polaris 850 xp performance parts
polaris xp 850 modifications
polaris xp850 high performance kit
power comander for polaris 850 xp
sportsman 850 xp power commander
where do i put my atv registration
where do i put my licence plate on my polaris atv
where do you put a license plate on a polaris atv
xp 850 power commander
xp850 power box
were to mount the license plate any suggestions Odds-r-even Polaris Sportsman 26 04-09-2010 09:02 AM
2009 xp 850 le ktmwoodsman ATVs For Sale 6 03-02-2010 04:03 PM
Cold Start Idle Problem - Suggestions Atv Dad Polaris Scrambler 4 11-08-2009 01:50 PM
2009 500 EFI vs 2009 500 EFI X2 a12 ATV Purchasing and Price 4 08-28-2009 09:28 PM
