Old 03-15-2010, 12:32 PM
kbhd6180's Avatar
Member #1827
Carb settings
Redid my 93 Trail Boss 250 2x4 took off the oil injection and am going with mix in the tank. Starts ok but doesn't seem to have any guts on the get go, plus it won't stay running at idle. My mix is 32:1 so I don't think it's starved for oil. Anybody got any ideas on initial carb settings. I went all the way in and came back out 2 1/2 turns then adjusted a little from there but it still has the same problem
Old 03-15-2010, 02:04 PM
Spitfire79's Avatar
Member #3532
Getting enough fuel to the carb? Float set properly? Is it backfiring? If so, through carb or exhaust? What all did you do?
Old 03-15-2010, 03:23 PM
kbhd6180's Avatar
Member #1827
Carb settings
The only thing I did to the carb was took it off and cleaned it. It is now backfiring through the exhaust. Won't start at all with a new battery and starter. The backfire happened when we tried to pull start. The only thing I did to the motor was to take off the oil injection pump and place a cover plate over where the pump was
Old 03-15-2010, 05:42 PM
Spitfire79's Avatar
Member #3532
When cleaning the carb, I assume you took it all apart, soaked it then assembled with new gaskets, needle / seat, etc? Backfire through the exhaust indicates a rich mixture. For some reason its flooding itself, then the excess fuel ignites in the exhaust where theres enough air to dilute the gas and reach the proper mixture to allow ignition. If you have a manual, it should tell you the initial settings for the float level, air screw, etc. Generally floats are set level with the carb body when inverted. The air screw should be about 1 turn out from lightly seated for intial starting and adjusted from there.
Hope that helps
Jeff
Old 03-16-2010, 04:49 PM
djtates125's Avatar
Member #2163
on my polaris 400 2 stroke i eliminated the oil pump and when u do so u need to rejet 2 sizes bigger than stock.
Old 03-17-2010, 06:30 AM
kbhd6180's Avatar
Member #1827
Carb settings
Spitfire
I reset the carb today and it wll kind os start but won't stay running. djtates says I need to rejet carb 2 sizes larger I would think that would just put that much more fuel in the carb. Any ideas?
Old 03-17-2010, 07:03 AM
Spitfire79's Avatar
Member #3532
When you mix oil / gas, the jet may need to be larger in oreder to account for the extra oil and same amount of fuel required. 1 - 2 jet size increase should do it. This is where you need to watch your plugs and piston wash. Its much easier to do on a sled where you can see inside the cylinder. At the very least, check your spark plug to make sure its not running too lean. It should be a nice light chocolate brown color.
That said, on 2 strokes, the main jet mainly effects the 3/4 to full throttle range. The needle jet and jet needle operate the 1/4 to 3/4 range and your pilot and air / fuel screws look after the idle to 1/4 throttle. There is overlap in these areas so theres a smooth transition through the rpm range.
Are you sure the choke is seated properly, and set properly? There should be about 1/8th inch free play in the choke lever before it starts to open the plunger. If the choke doesn't seat properly it will allow excess fuel into the carb and it will constantly flood. When it does start, does blipping the choke make it better or kill it?
Old 03-17-2010, 10:54 AM
kbhd6180's Avatar
Member #1827
Carb settings
Took the carb back off and checked everythig inside. It all looked ok put it back together and put it back on with a new fuel filter. Blipping the choke only makes it worse. Right now I have fuel mix on the floor under the bike coming from the exhaust outlet. I am at a loss at this point
kbhd6180
Old 03-17-2010, 12:05 PM
Spitfire79's Avatar
Member #3532
Have you checked the needle / seat? Maybe its allowing fuel to flow through? It's definately flooding.
Old 03-17-2010, 12:38 PM
kbhd6180's Avatar
Member #1827
Carb settings
I have the carb off the bike right now. If I push the throttle the sleeve inside that controls the needle goes up, but whenyou let off the throttle it takes a long time for the spring to push it back down. I also am not sure how far open that should be
adjusting polaris 50cc carburetor
carbuerator setting for a polaris scrambler 400
carburetor settings for polaris 50 predator
float level polaris 50cc
how to adjust carb on predator 50
polaris 250 carb adjustment
polaris 250 carb settings
polaris 400 carb adjustment
polaris 400 scrambler carb adjustments
polaris carb settings
polaris predator 50 carb
polaris predator 50 carb adjustment
polaris predator 50 carb tuning
polaris predator 50 carburator settings
polaris predator 50 carburetor
polaris predator 50 carburetor adjustment
polaris predator 50 carburetor settings
polaris scrambler carburetor settings
polaris trailboss 250 carb adjustment
New carb ridemhard Polaris Predator 15 03-17-2010 08:37 AM
95 polaris 300 2x4 carb settings? gregsta565 ATV Repair and Maintenance 2 02-15-2010 03:34 PM
04 scrambler Secondary Clutch settings? logicaldj Polaris Scrambler 8 10-19-2009 07:08 AM
Magnum 425 carb settings Ragin Cajun ATV Repair and Maintenance 1 09-15-2009 12:50 PM
Carb settings needed and Carb issues NolenGerke Polaris Trail Blazer 3 08-26-2009 03:30 PM
