Check engine light on already! - Polaris ATV Forum
post #1 of 9 (permalink) Old 03-09-2013, 01:11 PM Thread Starter
Moomba's Avatar
Quick question for all those that know more than me - which is all of you!
I have a 2013 850 XP Sportsman. The other day was the first time I have used this ATV to push snow (had an 07 sportsman 500 previously to push snow) and the check engine light came on. I have 41 miles and about 12 hours on this machine.
Here are the details.
I pushed my first driveway without any issues. I loaded the 850 onto the trailer, left it running and went to my next job which was about 15 miles away. It was still snowing when I left. When I got there, I hoped on, put it in reverse, hit the throttle and it died. No big deal, I started it back up, put it in reverse and tried again. The engine light came on and it ran fine as long as I didn't give it throttle. If I tried to throttle, it sounded like I was choking it out. I let off and it was fine (engine light now blinking).
So I took it home, ran the check and it gave me 520194 - 2 and 7 which relates to Throttle Safety Signal. The 520194-2 is the Signal out of Range and the 520194-7 is Throttle Stuck. The signal out of range I have no clue about. The throttle was not stuck because I could move it and I can hear it moving within the throttle body. So then I took the air filter off because thats what I always do when something doesn't run right and a mouse had made him a nice little home in there. The filter seemed like it was half off but I don't think anything got up in there. I put it back together and started it up and it ran fine. No engine light, nothing. So now I stared to wonder if I really had any issues with it. It was early in the morning plus it was a new ATV so I was guessing myself.
I went back out pushing snow but this time shut it off in between driveways. I pushed 3 more driveways and it did it again. Now I'm pissed. I figured out that if I just played with the throttle it would take off and run correctly but it continued to act up. I figured I spent an extra 2 hours just fighting thru the issue with the next 4 driveways.
I called the dealership I bought it from and they said to bring it in. Normally I would but the dealership is about 70 miles away. I'm wanting to know if anyone else has had this issue and how they fixed it. I don't want to drive all that way for a simple fix. The air box was dry, the plugs were dry, checked all the wires around the throttle and around the fuel injection and made sure they were all pushed in and connections tight. The fuel was the same I used in my truck with no issues. Any help or advice would be great! Thanks and sorry for the long ass story!
Moomba is offline
post #2 of 9 (permalink) Old 03-09-2013, 01:57 PM Thread Starter
Moomba's Avatar
I may have put this in the wrong thread!
Moomba is offline
post #3 of 9 (permalink) Old 03-09-2013, 08:34 PM
Amdforever's Avatar
If its under warranty, I'd take it to them first. You messing with stuff could void any warranty claim after they realize you've been tampering with it. Much easier for them to say you did it while trying to fix it.
Amdforever is offline
post #4 of 9 (permalink) Old 03-09-2013, 08:50 PM
Bruce! is offline
post #5 of 9 (permalink) Old 03-10-2013, 04:38 AM
bgirard420's Avatar
Have you tried adjusting the throttle freeplay?
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
post #6 of 9 (permalink) Old 03-10-2013, 05:29 AM
Diesel man 03's Avatar
Throttle free play seems to need attention.
Diesel man 03 is offline
post #7 of 9 (permalink) Old 03-10-2013, 05:53 PM Thread Starter
Moomba's Avatar
The throttle seems to be OK. There is atleast 1/8" of free play in it. I'm just going to take it back to the dealer and let them mess with it. Thanks for the help!
Moomba is offline
post #8 of 9 (permalink) Old 06-10-2013, 09:23 PM
turboshelby's Avatar
Re: Check engine light on already!
Plowing snow usually involves a lot of lock to lock steering. Cable free play can change on tight turns, especially if the cable has been moved, like when you install a windshield etc.
Sent from my XT907 using Tapatalk 2
2009 850 EPS - 2500 miles and counting
2009 550 EPS - 8200 miles and counting
2006 500 EFI - 18,700 miles and *SOLD*
turboshelby is offline
post #9 of 9 (permalink) Old 08-03-2013, 05:54 PM
gat
gat's Avatar
what was the problem on the 520194 - 2 code?
2011 sportsman xp eps stealth black
sti hds se wheels
27" swamplite tires
1" spring spacers front and back
polaris deluxe rear bumper brushguard
polaris extreme front brushguard
lock & ride front cargo box
Polaris steel rear rack extender
aluminum products a-arm gaurds
aluminum products skid plates
Polaris hand/thumb warmers
polaris 2500lb winch
jc capri bushings
14" led light bar
k&n filter
gat is offline
Check engine light scott_r ATV Repair and Maintenance 11 08-31-2016 07:27 PM
Engine stalls/ check engine light flashes 2quick ATV Repair and Maintenance 4 05-26-2013 06:32 AM
Check engine light FuntanaS ATV General Discussion 2 10-17-2012 12:44 PM
Check engine light lilbuddy3 ATV General Discussion 4 04-05-2012 10:55 AM
hot/check engine light pottsville30 Polaris Sportsman 11 06-27-2010 11:39 AM
