Old 04-21-2010, 06:44 PM
rugnuts's Avatar
Member #4455
Low End Improvement for a 550xp???
just bought my first 4-Wheeler 2 months ago. 2009 550XP
On a flat road, my sporty hits 60-62mph (depends on wind)
but it takes a long time to wind up to it.
i would like more get up and go and im willing to lose some top end for more snap. a buddy traded in a '06 500 HO EFI for a new '09 850XP. he claims that his old 500 felt snappier than my 550XP. can this be true?
im leaning on getting a clutch kit but the market looks limited for the 550's, i've found several other options for the 850's. i also plan on upgrading the tires so i will need a clutch kit to get em turnin!
This
is the only clutch kit ive found for a 550. are there any others?
these are the tires im lookin at. 27x9x14 / 27x11x14
ive read some stuff about having to bend a swaybar, any tutorials on what exactly we're bending and how to do it best?
and i'd prefer to stay away from exhaust and intake for now.
Old 04-21-2010, 07:13 PM
09 Sportsman's Avatar
Member #3684
I have a 550 xp and mine runs about the same. I can tell you you'll lose some with those 27" tires. I am not sure your friend remembers how the quad he's referring to actually ran. Unless you just have a dog, yours should be noticeably faster.
My 550 is totally stock so I don't know much about clutch kits. Maybe some other guys will chime in.
2012 Sunset Red XP 850 HO EPS- Everything.....
2010 Sunset Red XP 850 EPS;6000K 55W HIDS, Deluxe front and rear brush guards, 3500lb winch, heated grips and thumb, front and rear rack extenders, polaris hand guards, (2) 2gal Rotopax, Lock and Ride Gun Boot, Lock and Ride Rear Cargo Box
2009 XP 550 Browning Edition- Stock
Old 04-21-2010, 08:29 PM
denseleit's Avatar
Member #2441
Here's the high altitude clutch kit part number.
0203-2587 Polaris Clutch Kit, 550 Sportsman XP, Stock Tire 2008-2009 3-6000 FT $199.95
2009 Sportsman XP 850 W/30" ZILLA'S, Team industries 14% gear reduction kit & high altitude clutch kit,3.5 degree advance key,heated grips,superwinch terra 4500,.
2011 RZR w/28" Zilla's, superatv springs, seatbelts and bunch of goodies.
2002 33' Tahoe toy hauler
2008 F350 FX4 crew cab diesel,spartan tuned,S&B,4" back.
Old 04-21-2010, 08:32 PM
i like these guys as clutching kits goes. thats my .02
heelclicker also makes a clutch kit i believe
Old 04-21-2010, 08:55 PM
denseleit's Avatar
Member #2441
They have 4 different kits for the 550/850. Stock tire low altitude, high altitude and big tire low altitude and high altitude. The last 4 digits go from 2586,2587,2588,2589.
Old 04-22-2010, 10:42 AM
rugnuts's Avatar
Member #4455
ERROR in original post "it was a "600 HO EFI" but either way...
question about the Hot Seat's?
they are labeled for "550XP/EPS" are they designed to work withOUT EPS also????
do these clutch kits have any special setup or tuning? or do you just replace the stock springs and weights with the new ones? any special tools?
Old 04-22-2010, 11:44 AM
rugnuts's Avatar
Member #4455
tire questions.........
i want to use my stock rims. my terrathons are 26x8-14 and 26x10-14
for the brand i want, the 14" tire options are:
26x10
26x12
27x9
27x11
1. do i add 1" width and 1" of height all around? will i still have spacer issues?
2. or could i just put the 26x10 all around?
3. or do i keep the stock height and go 2" wider all around?
***i am assuming i can put a tire that is 2" wider on stock rims***
Old 04-22-2010, 02:18 PM
kling2001's Avatar
Member #3575
check this thread out, you may find your answerBigger tires on '09 XP 550
Old 04-22-2010, 04:07 PM
as far as hot seat goes, im 99% sure it will work on non-EPS machines. i cant imagine a single factor that would cause it not to work. but you can call them and ask. super friendly people, they will answer any question you have. thats why i always recommend them, their customer service is top notch. same with the tools question and what not. call them, talk to them, they will tell you what you need, what it takes to install it, everything. they do all the leg work for you and will stand behind their product if you have problems or questions, even way after the sale.
Old 09-24-2010, 07:48 AM
NickXP550's Avatar
Member #5331
Look at an EPI Clutch Kit. I installed one on my 550 and it improved the low/mid range performance a lot. Top speed wasn't really affected either. I still can hit 60mph easily with no engine mods. It was a good investment and not to hard to install.
14% gear reduction kit 2011 polaris 550
2011 polaris xp 550 clutch kit
30'' silverbacks on 550 xp
550 xp clutch kit
550xp exhaust
atv exhaust for 2007 polaris 550xp
best clutch kit for xp 550
cluch kit for 550 xp
clucth improvements for polaris atv
do i need a clutch kit to run 28's on my 550 xp
epi clutch kit polaris 550 sportsman xp
polaris 2009 xp 550 cab
polaris 550 xp clutch kits
polaris 550 xp performance exhaust
polaris industries forums xp550 2009 problems
polaris sportsman 55o xp clutch
recommended epi clutch springs for 550xp polaris
tire kit for polaris 550xp
xp 550 clutch kit
xp 550 intake height
How to set idle 2010 550xp?? MUDDIE49 Polaris XP 13 06-07-2010 07:46 PM
Electrical wires '09 550XP nmpolaris Polaris XP 5 03-28-2010 05:46 PM
Back up lights for 550XP flint Polaris XP 22 01-29-2010 05:12 AM
550XP Clunky Transmission bspiening Polaris XP 5 12-05-2009 11:01 AM
550xp vs 700 efi Polaris Bear ATV Purchasing and Price 16 08-06-2009 08:24 AM
