  #11 (permalink)
Old 03-26-2011, 06:49 PM
gmb357's Avatar
Member #6962
Did ya cut a few coils outta the needle spring so its less fiem so the diaphram can react more quickly for better throttle responce?
  #12 (permalink)
Old 03-26-2011, 06:54 PM
Diesel432's Avatar
Member #10816
No I didn't you think that will help. I also adjusted the a/f screw 3 turns open
  #13 (permalink)
Old 03-28-2011, 08:27 AM
ridemhard's Avatar
Member #3442
Did you say 2 K&N filters? that can be your problem right there. Aslo i would look into a 150 jet, sounds like it running rich
  #14 (permalink)
Old 03-28-2011, 10:30 AM
Diesel432's Avatar
Member #10816
Yeah 2 kn air filters Thats what the cfm air box I have uses. Idk it had a 155 with all the stock parts on it and it ran great that's why I figured I needed to go up.
  #15 (permalink)
Old 05-06-2011, 06:03 PM
EricOnAPredator500's Avatar
Member #4200
We both have 2007 Preds, so I was wondering, when you said you used a 170 main jet, is that a Mikuni or Dynojet? And do you have the stock Mikuni needle or a Dynojet needle? I'm using a clamp-on filter straight to the carb and a full Yoshi exhaust. I'm using a 170 Dynojet and it works best so far! I put in a 147.5 pilot, but I haven't moved the pilot screw from it's stock 2.5 turn position yet. I did drill out the plug though. My needle is the stock one and I put it one richer on the 4th notch (raising the needle). Seems to run good. I tried bigger Mikuni jets and the results sucked ass! A Mikuni 167.5 and 165 were too big for my setup. I also tried the richest position on the needle and it was no good.
I go in balls deep or I don't go at all!
-Pro aluminum bumper and grab bar
-Tusk heel guards and gas cap
-CFM racing air scoops and oil tank
-UM racing swing arm guard
-J n J industries full skid plates
-Mikuni carb needle at 4th notch with 170 main jet
-UNI pod 4" X 4" filter directly to the carb
-Full Yoshimura RS3 exhaust
  #16 (permalink)
Old 07-03-2011, 12:26 PM
ETV13's Avatar
Member #16483
I'm on a 07 also, HMF pipe, cfm airbox at sea level. I went with dynojets, 175 main, stock pilot. If you're struggling at midrange adjust the clip on the needle to the 3rd or 4th notch rather than the mainjet. If you're going to use a dyno main jet use the dyno needle with it.
2005 polaris predator 500 jetting
2005 polaris predator jetting
best jetting 06 polaris predator 500
do i need to rejet with a k&n filter and a slip on
jetting diagram polaris predator 500
jetting polaris predator 500
jetting predator 500
mikuni jets predator
moose polaris predator 500 jetting
polaris 500 jetting
polaris predator 500 carburetor factory jets
predator 500 stock clip position
pure polaris exhaust jetting
stock jetting on 03 polaris predator
suggested pilot size predator 500
what is stock jeting on 05 polaris predator 500
what jetting should be on predator 500 with fmf pipe
Predator 500 tire question Silverarrowclk ATV Wheels & Tires 3 08-20-2010 07:22 PM
Predator rear wheels question peete46 Polaris Predator 1 08-10-2010 05:11 PM
A question about jetting stmoxy ATV General Discussion 2 07-22-2010 10:44 AM
Predator shock question redneck2725 Polaris Predator 16 04-06-2010 01:27 PM
predator 500 question nathangillilan ATV Repair and Maintenance 3 02-16-2010 02:38 PM
