08-13-2011, 05:20 PM
Member #17674
2008 sportsman 800
I just bought this machine, sight unseen. My old lady and my best friend went and checked it out for me since I'm on the road. It sounded like a pretty good deal so I bought it.it has 2700 miles on it, a quick release plow, and a winch. Hand guards, and the camo color also. What do you guy think? I paid 4350
08-13-2011, 05:29 PM
Member #1042
Change your fluids, and be careful to check over your transmission properly. Listen for any clunking, or hard engagement. Otherwise sounds good to me
2005 sportsman 400 4x4 Indy red
-Rad relocation
-EPI clutch kit
-EPI front arms
-12 inch Polaris alloys, 26 inch Carlisle Pxt's
-Front and rear bumpers
-3500lb Runva winch, synthetic cable
-Rear worklights
-Hand and thumb warmers
WISHLIST
-26inch Act xlr's
-Gorilla axles (maybe not, $$$!!!!)
-H.I.D. Lights
-Supertrapp mudslinger muffler, or AAEN Megaphone
-Graphic dipped bodywork, Snow Camo
1979 Yamaha Enticer 250
Terra jet
2003 Yamaha fjr1300-power commander (dads)
1997 Bmw 328i
2011 Dodge ram 1500 laramie (hunter green pearlcoat, dads)
[SIGPIC]
08-13-2011, 06:11 PM
Member #17674
Thanks for the reply trailboss. I'll give her the good ole' how do you do as soon I get home and pick it up. I didn't think to change the fluids but that's probably a safe bet so I know when they were done.
08-16-2011, 04:56 PM
Member #17674
ok i just picked it up, i'm not impressed with the read suspension. i'm a good sized feller but i think it should way tighter than it is when it is tightened all the way. any idea if you can rebuild these shocks? and how much it would cost? thanks.
08-16-2011, 05:02 PM
Member #1042
You would probably be farther ahead just replacing them. They shouldn't be too expensive, and it would require quite a few special tools and a bit of experience to do it. Shocks are something I have yet to rebuild, but are something I would prefer not to. It can be dangerous if done incorrectly. I'm not even sure if the Polaris ones are rebuildable. It should be able to handle the weight no problem, my dad weighs 270lbs and I weigh 185, and we both ride two up on mine no problem, with him on the back. It is very similar rear suspension, if not identical
-Rad relocation
-EPI clutch kit
-EPI front arms
-Rear worklights
WISHLIST
-26inch Act xlr's
-H.I.D. Lights
Terra jet
1997 Bmw 328i
[SIGPIC]
08-16-2011, 05:10 PM
Member #17674
thanks again trailboss. i think i will check into the price of shocks. i know a very good atv mechanic that i will probably call on to help with that process, since he would have the tools and know how. thanks again.
08-16-2011, 05:14 PM
Member #1042
Anytime, let me know how it goes
-Rad relocation
-EPI clutch kit
-EPI front arms
-Rear worklights
WISHLIST
-26inch Act xlr's
-H.I.D. Lights
Terra jet
1997 Bmw 328i
[SIGPIC]
08-16-2011, 11:22 PM
Member #4649
Before you spend money on shocks, where is the preload set at? The rear springs are adjustable.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
08-17-2011, 08:19 AM
Member #9763
If your machine is sagging it is the springs not the shocks. Order you some HD springs from EPI or Highlifter and be done with it. They are easy to install.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
08-17-2011, 09:08 AM
Member #17674
ok i'll probably go that route. i haven't had a chance to tighten the last notch but it is only one notch from the top. and now that i have put a few (15) miles on it... i hear a noise that doesn't sound right to me. it sounds like a chain sort of noise, kinda like teeth barely grinding. it's hard to explain, but i think this machine was used to pull stuff and such as a farm wheeler. how do i check the transmission to see if that's where the noise is coming from? any ideas?
05 sportman 800 rear u joint, 08 sportsman grinding when in gear, 2 lift for sportsman 800 2008, 2008 800 polaris front bumpers, 2008 polaris sportsman 800 fluid change, 2008 polaris sportsman 800 rear springs, 2008 polaris sportsman 800 suspension springs, 2008 polaris sportsman 800 transmission problems in low gear, ghanging u joints on a sportsman 800, grinding noise when decelerating sportsman 800, ho do u install rad to top rack on 08 800 pollaris, how to change the u joint on a sportsman 800, how to clean the diff fluid on polaris atv sportsman 800, is there front differential fluid on. a 2008 800 polaris sportsman, polaris sportsman 800 u-joints, sportsman 800 axle change, sportsman 800 polaris transmission oil change, triangle atv aaen performance 800 spoetsmen, u joints clicking spoetsman 800, value of 2008 polaris sportsman 800
