Go Back   Polaris ATV Forum > Polaris ATV Discussions > ATV Purchasing and Price
ATV Purchasing and Price Getting ready to purchase your first ATV? Discussions concerning ATV comparisons, models, prices, and all purchasing related questions.
Old 10-17-2011, 01:42 AM
MarkD's Avatar
Member #19647
Exclamation Buying a 250 TrailBlazer points to look out for?
As above, Im going viewing a Polaris TrailBlazer with the intention of buying later today, what are the main points to look out for on these atv's and also do ye recommend them as a good machine? Im a little concerned about them being auto as I think manual would be more fun for sideways action and the likes.
Are these atv's good fun and powerfull compared to rival 250cc 4stroke manuals?
Hope ye can help.
Mark from Ireland
Old 10-17-2011, 06:00 AM
Old 10-17-2011, 06:49 AM
Welcome Mark,
I do not know how mechanically inclined you are, but they are pretty easy to scope out. You are looking for the usual signs of fluid leaking on any of the cases or the frame rails, check out all of the rubber hoses and components for cracks or breaks. Especially the motor mounts. I believe there are 3 rubber motor mounts. You want to push on the motor and see if the rubber separates.
The biggest indicator will be riding it. Does it start easy? Any ticking? Are you familiar with 2 strokes, and how they idle run? How does it take off? Any squeals?
Basically looking for any noises that are not a good sign on any mechanical machines. These machines are super simple though. They are also pretty fun, it will get sideways for you!
A 250cc 2-stroke is going to be faster and quicker then a 250cc 4-stroke, since on a 2stroke you are getting ignition on every stroke, where as a 4stroke only has ignition on every other stroke.
Old 10-17-2011, 07:06 AM
dwhst9's Avatar
Member #11907
Send a message via AIM to dwhst9 Send a message via Yahoo to dwhst9
Take a compression tester and test it. You'll know if it needs a top-end rebuild. Anything 100 psi or lower and will need a rebuild. 125 psi would be around stock I believe.
Old 10-17-2011, 03:55 PM
MarkD's Avatar
Member #19647
Thanks for the welcome and the information fellow members.
Quad was running, starting and driving A1 when I bought it tonight no leaks etc etc but then among all the excitement we ran out of petrol on it and now it wont start! Been at it for hours
Here is the technical help thread I started, please add your helpfull information here.
I would be greatfull of all help
price on a 250 trailblazer
DIY Home Maintenance Points blueline15 ATV Repair and Maintenance 36 03-08-2012 09:26 PM
Ground points on Sportsman 500 EFI?? eastern_hunter ATV Repair and Maintenance 0 05-24-2011 02:31 PM
looking at buying a 700 sportsman countryboy89 ATV Purchasing and Price 1 06-19-2010 07:17 PM
Rath Takes Over GNCC “4x4 Open” Points Lead 4Nines Polaris ATV News 0 04-13-2010 07:47 AM
Front end grease points on a 2009 Trail Boss Orion6 ATV Repair and Maintenance 2 04-11-2010 04:56 PM
