Go Back   Polaris ATV Forum > Polaris ATV Discussions > ATV Purchasing and Price
ATV Purchasing and Price Getting ready to purchase your first ATV? Discussions concerning ATV comparisons, models, prices, and all purchasing related questions.
Old 01-03-2012, 07:11 AM
garrett1812's Avatar
Member #20121
Buy a 1997?
A shop nearby is offering a 1997 Sportsman 500 with 450 hours/291 miles for $2500. Is this a good buy? I really do not want to buy a project. Being so old makes me a bit nervous, but with low miles it sounds promising? I don't have $8k to throw at a new machine right now, so I am curious if people think this would be a good buy.
Old 01-03-2012, 08:41 AM
antoniodef's Avatar
Member #11247
If it is clean and they let you drive it and check it all out I would buy it.
Make sure the four wheel drive works. If it doesn't and you are mechanically inclined you can fix it, but it could get pricey.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
Old 01-03-2012, 09:32 AM
Member #20121
Might be a dumb question, but how does one test the four wheel drive? I am assuming I can only test it in the parking lot of the shop.
Old 01-03-2012, 11:33 AM
antoniodef's Avatar
Member #11247
Lift it up with a jack. The shop selling it should have one. Make sure the 4wd is on and give it a little throttle. All four tires should turn.
Old 01-03-2012, 11:44 AM
factionfx's Avatar
Member #20681
I have 8 hours and 75 miles on my new machine. If it has 450 miles and 291 miles, it has probably seen some hard times in the mud.
2012 Sportsman 500, Red.
Old 01-03-2012, 01:07 PM
4getful2's Avatar
Member #1234
I don't quite understand the hours/miles . I'd be a bit scepticle of that,unless grandpa drove it down his lane to get the mail or some wood and left it run ,while loading, OR the speedometer has been broken and the miles aren't right . 2500-4000 miles would more believeable.
You can look on kelley blue book and see about what it's worth,i go by trade-in value,since you are buying it outright.
You can jack up the back wheels off the ground and see if the front wheels are pulling,check the front inside yokes on the differential for play,if it's excessive,they are kinda costly to replace.
Good luck
Old 01-04-2012, 04:44 AM
Member #20121
Duh..don't know why I didn't think of that. Thanks.
Old 01-04-2012, 05:25 AM
Member #1958
With 450 hours it should have around 3-4000 miles. If its in excellent condition it should be worth somewhere between $1200 - $2000 retail according to what has been done to it and any extras like new tires, winch, hand warmers and guards, rack extenders, etc.
Old 01-04-2012, 06:29 AM
Member #20121
I do not think it has much done to it. If I could get it for $1200 that would be a worthwhile try, I think.
For the hours/miles. The hour counter will still count even when the engine is idiling, correct? If so a lot of idiling time could explain the high hours/miles ratio.
Old 01-05-2012, 07:37 PM
Member #20121
I got some more info on the machine today. It may be 291 miles/450 hours or 450 miles/291 hours. I heard both from two different people. The atv was owned by one of the shop managers or owners, and was used for mudding. Mud tires are installed - how would those do on wooded trails? Is mudding really abusive on ATVs?
1997 trailbblazer 250 price
crossover oil filter 97 polaris 500
1997 Xplorer 500 Burghfan913 ATV New Members 1 08-21-2011 05:49 PM
1997 425 cam question geomerc Polaris Magnum 0 06-01-2011 07:57 PM
1997 Magnum 425 JohnII ATV Purchasing and Price 4 05-10-2011 03:58 PM
1997 Trailblazer 250 mobilefleet ATV New Members 1 10-31-2010 07:52 PM
1997 sportman s4point ATV New Members 0 10-22-2009 09:32 AM
