Go Back   Polaris ATV Forum > Polaris ATV Discussions > ATV Purchasing and Price
ATV Purchasing and Price Getting ready to purchase your first ATV? Discussions concerning ATV comparisons, models, prices, and all purchasing related questions.
  #21 (permalink)
Old 02-04-2012, 07:20 PM
WilliamBos's Avatar
Member #5254
Send a message via Skype™ to WilliamBos
Originally Posted by ZPO View Post
Originally Posted by WilliamBos View Post
Originally Posted by hubbard738 View Post
I would be concerned about riding comfort, My outty 650 gets so hot in the summer riding it will burn the hair off your legs. My 850 XP rides much cooler and a lot narrower at your knees and feet alot more comfortable to ride. I would amagine that CanAm 1000 must be as wide as horse.
They did improve the cooling system on the new G2 chassis. Does Polaris have a patent on the way the engine is rotated on the XP? I see no one else has done it.
Hasn't Honda had this configuration for a while. It makes sense since it's one less 90 degree turn for the power transmission.
Thanks. You are right, honda has had it for a while. :-)
Thanks,
Will
2004 GMC 1500CC Z71.
  #22 (permalink)
Old 02-04-2012, 09:32 PM
Forrest's Avatar
Member #21911
Originally Posted by 800touring View Post
I am looking to drop my 850 down on a new xt 1000 can-am because my dad wants to trade brands. So I have been looking around at both bikes and found some pros and cons of the bikes
Can-am problems for the new XT outlander is
the black end piece on the brush guards brake off easy.
you have to buy the eps model for Visco lok QE
Needs skid plates even on the new G2 frames
Back trunk opens randomly some times
first year model
Polaris bads
Needs better skid plates
some bad welds A arms frame (not that common tho)
needs brush guards front and back
Bad MPG 9.4 mpg with hard riding so this is like low as possible almost 6 gallons
Goods for can-am
Good throttle response
grate MPG 14.1 with 5 gallon tank
smooth ride
for sure faster
Don't you want to see a 1000 label on the side
New G2 frame
3 mode EPS
ROTAX V Twin. Enough said
Polaris goods
Best work bike made
Best 4x4 system
Best usable ground clearance
new and Improved air box
Best ride
Best price but you do get your moneys worth of stuff on the can-am
4 years being made so bugs are almost all worked out
narrow seat because in-line twin
better for hunting then the outlander
smother control of power
You stay with the same brand
My 12 850 has a 5+ gallon gas tank. The new ones do.
  #23 (permalink)
Old 02-05-2012, 09:31 AM
800touring's Avatar
Member #14149
first year model
Polaris bads
Goods for can-am
smooth ride
for sure faster
New G2 frame
3 mode EPS
Polaris goods
Best work bike made
Best 4x4 system
Best ride
the 2011 and 2012 850 have about a 5.5 gallon tanks witch it have got about 80 miles out of but also have got only about 50 when having fun
  #24 (permalink)
Old 02-06-2012, 06:55 AM
golf12's Avatar
Member #14456
In its current form, all evidence and test after test by the pro's supports that the xp is still the best all around big bore in the business at this point.. In a drag race the oulander is gonna win, but not by more than a quad length or two tops.. Thats all the outlander has on the xp.. I have no doubt that the outader is a fantastic machine and brp has done wonders for its ride and handling.. You'll love it if buy it, but you'll be riding the second best atv on the mkt.. Thats just a fact.. And you know know whats gonna happen right?..Though its closer than before, the outlander is still in the xp's rear view mirror.. You'll buy the outty in 2013 just in time for polaris to make changes to the xp that puts the outlander even further behind it..
  #25 (permalink)
Old 02-06-2012, 08:10 AM
zoomeroo's Avatar
Member #18920
outlander 1000 or polaris 850
The outlander gets way too hot on your legs when riding in the summer. I was told this was one of the main reasons polaris turned the engine on the 850. I rode the Can Am and hated all of the heat so i bought the polaris. I haven't ridden the 1000 but with what the 850 has to put out I find it hard to believe anyone would need a bigger engine. I think it is honda that makes around a 600 cc and it's only like 30 couple horsepower. I wonder if the Can Am will be the same way? Lots of CCs but no rear improvement on performance.
  #26 (permalink)
Old 02-08-2012, 03:40 PM
bp405's Avatar
Member #18562
just hoping that polaris bumps the xp up to 80 or so hp for 2013. definetly going to goto a couple of events where i can test drive and shot the shiznot with some people who ride both machines. going to most likely stay within the family but need to make the right decision for the long term.
2011 sportsman 800 efi
polaris front brush guard
polaris rear brush guard
polaris front lock n ride cargo box
polaris rear rack extender
warn RT 3.0 winch
polaris front spring adjusters
ricochet a-arm guards
ricochet full frame skid plate
itp T-7 beadlock 14"
maxxis big horn 2.0 26x9 front
maxxis big horn 2.0 26x11 rear
QSC clutch kit
  #27 (permalink)
Old 02-08-2012, 03:44 PM
bp405's Avatar
Member #18562
i'm going todo a little reaserch myself but any input would be helpful. question 1-how do the differentials in the xp work? 2-what are the torque values on the 2012 850 xp.
warn RT 3.0 winch
QSC clutch kit
  #28 (permalink)
Old 02-08-2012, 04:31 PM
Rooskey's Avatar
Member #22134
I cant believe the outlander weigh's rite at 900lbs. Imagine rolling that thing on top of you!
  #29 (permalink)
Old 02-08-2012, 04:45 PM
bp405's Avatar
Member #18562
the outlander 1000xt dry weight is 747lbs. and the sportsman 850xp eps dry weight is 773lbs.
warn RT 3.0 winch
QSC clutch kit
  #30 (permalink)
Old 02-08-2012, 07:02 PM
Forrest's Avatar
Member #21911
first year model
Polaris bads
Goods for can-am
smooth ride
for sure faster
New G2 frame
3 mode EPS
Polaris goods
Best work bike made
Best 4x4 system
Best ride
Looked it up tonight, 2012 850 XP = 5.25 gallon tank.
2013 can am outlander
2013 can am outlander 1000 xxc
2013 can-am outlander
2013 outlander max 1000
2013 polaris 850
2013 polaris atv
2013 polaris atvs
2013 polaris sportsman 850
can am 1000 vs polaris 850
can am or polaris
can am outlander 1000 compared to polaris 850
can am outlander 1000 vs polaris 850
can am outlander g2 chassis problems
is polaris coming out with a 1000
outlander 1000 price
polaris 1000 atv
polaris 850 or outlander 1000
polaris 850 vs can am 1000
when is the 2013 polaris xp coming out
Sportsman 850XP or Outlander 1000? Donovan514 Polaris Sportsman 26 01-10-2012 12:05 PM
New 2012 Can Am Outlander and Renegade 1000!!! kool_500HO ATV General Discussion 18 08-08-2011 05:53 PM
Polaris Sportsman 850 Touring vs Outlander 800 Max STRADALE Polaris Sportsman 24 12-08-2010 04:32 AM
Polaris 850 Shootout VRS CanAm OutLander 800 PolarBear ATV Media 3 10-02-2009 01:21 PM
