Go Back   Polaris ATV Forum > Polaris ATV Discussions > ATV Purchasing and Price
ATV Purchasing and Price Getting ready to purchase your first ATV? Discussions concerning ATV comparisons, models, prices, and all purchasing related questions.
  #11 (permalink)
Old 09-10-2010, 04:37 PM
cwlongshot's Avatar
I found one!!
Quadboss Rear Rack Mounting Kit for Sport ATVs - Cheap Cycle Parts
http://www.cheapcycleparts.com/produ...t-atvs?find=H2
  #12 (permalink)
Old 09-10-2010, 05:07 PM
i was going to say that yes, the rear rack is still available.
  #13 (permalink)
Old 09-12-2010, 12:02 PM
cwlongshot's Avatar
Well.
Everything changed... Started looking locally and ran across five machines. All exactly what I want all in the price I wanna pay!
I ended up with a 2001 TrailBoss 325 4x2.
It needs some TLC but for the price I am happy. It runs, starts and rides great.(it's minor) Biggest issue is the steering linkage. There is some kind of bushing at the end of the shaft where the inboard tie rods attach. That appears to be worn. The pass side lower A arm is tweaked. The rack itself took a hit as did the front bumper. But both easily repairable.
Thanks for all the tips and advice guys!!
  #14 (permalink)
Old 08-30-2011, 07:18 AM
chillidogg's Avatar
Member #18169
Important Service Advice!!!!!!!
I have a couple of older ATV one is a 1997 Trail Boss 250cc. Well the most recent thing is a starter problem. This could have been prevented if the starter had been properly drained. There is a drain plug under the pull start housing and also one on the starter housing they should be drained anytime use around water....and maybe just periodically drained for GP. I had not had any problem with the starter for the first two years that we owned it, but after a friend it on some serious mud excursions. He thought he had cleaned it up pretty well and it looked like new again. This is my daughter secondary ride and usually just sits around until friends and family want to ride...the starters OEM price is pretty costly around $300 to $350 +S/H. I have since found an aftermarket starter for less than a $100....but had I know this from the start it would have saved me plenty of head-ache and frustration. Because of it just sitting it caused the starter to complete rust together internally
1986 polaris trail boss 250 blue book price
1990 polaris 250 trailboss
1990 polaris trail boss fluid
1990 trailboss 250 winch
1997 polaris trail boss 250
1997 polaris trailboss transmission oil
1998 polaris trail boss 250
1998 polaris trail boss 250 gear case oil
2000 polaris 325 trail boss
2000 polaris trail boss 250
2001 polaris trail boss logo
97 trail boss oil transmission
how to change transmission fluid trail boss 330
how to fix the transmission in my 1986 polaris trail boss 250
polaris 325 what years made
polaris trail boss 325 winch
what color were 1998 polaris trail boss 250
what years did polaris make the 250 trail boss
what years did polaris make the 325 trail boss
trail boss bomberboat ATV General Discussion 17 02-16-2012 04:44 PM
86 trail boss peewee ATV Repair and Maintenance 6 08-29-2010 08:48 AM
91 trail boss 350 fowler1977 ATV Repair and Maintenance 4 01-07-2010 10:22 PM
Trail Boss 250 tbuzz ATV Repair and Maintenance 1 09-04-2009 07:12 PM
trail boss 330 scottb ATV Repair and Maintenance 8 07-12-2009 09:04 PM
