Go Back   Polaris ATV Forum > Polaris ATV Discussions > ATV Racing Discussion
ATV Racing Discussion All ATV Racing here! Amatuers, Semi and Professional Racing Talk.
Old 10-26-2010, 12:13 PM
Ironwill's Avatar
Member #8192
JE or Wiesco Piston?
I am thinking of getting a high compression piston in my Predator 500. Which piston is the better choice JE or Wiesco?
Old 04-18-2011, 06:13 PM
weedy's Avatar
Member #2147
I have used several WISECO pistons and they were excellent. No idea on the JE.
2005 SP 500
2004 SP 500
2002 SP 500-SOLD
2001 SP 500-TOTALED
Old 04-19-2011, 12:40 PM
icefishur96's Avatar
Member #10391
X2 on the Weisco! I have used them several times with excelent performance!
2000 Scrambler 90
2008 Sportsman 500 H.O. EFI
2011 RZRs LE
Accessories from www.TheATVSuperStore.com
Old 09-14-2011, 04:00 PM
joshr08's Avatar
Member #13071
i run wiesco in my big bore predator. to be honest with you for the time and money involved i wouldnt do a 12.5-1 stock bore upgrade. Just my opion but your not going to really get much out of the money you are going to spend. maybe 1-2hp if that. the big bore will only get you about 5-6 hp but either way your still tearing the motor down the same amount and paying for gaskets. check ebay i got my big bore piston for 100 bucks(cheaper then the hi comp stock bore piston) and then i got an advanced sleeve(sister company of wiesco) then took it to my local race builder and had him bore and sleeve my cylinder.
piston to cylinder clearance for a 500 polaris predator
polaris 500 high compresion piston
polaris 500 scrambler high compression piston
piston clearance jefteland ATV Repair and Maintenance 4 Yesterday 04:01 PM
What happened to my piston?! thebode11 ATV Repair and Maintenance 8 10-27-2010 07:15 PM
need help in ordering piston John Richards ATV Repair and Maintenance 2 08-04-2010 05:35 AM
How Do i Remove the Piston Pin? itscody ATV Repair and Maintenance 3 06-27-2010 02:19 PM
97 Xplorer 400 Piston 38A ? DirtDobber ATV Repair and Maintenance 0 05-05-2010 06:27 AM
