05 Polaris Predator 500 - Polaris ATV Forum
post #1 of 9 (permalink) Old 11-29-2010, 01:31 PM Thread Starter
Eagles22793's Avatar
I am having trouble with a starting issuse on my predator 500. It is not getting spark and I followed it to the coil by hot wiring the kill switch and key switch to makesure non of them were bad. I am not getting power to the single white with blue stripe coil wire when cranking or not cranking the bike. I am just wondering if any body has any problems with the magnetos or coil on these bikes? Or can someone guide me in a direction I have a pretty good experience working on bikes but not with electric starts. Wiring diagram will be also nice if someone has a site to one I dont have a manual.
Eagles22793 is offline
post #2 of 9 (permalink) Old 11-29-2010, 01:39 PM
Bruce! is offline
post #3 of 9 (permalink) Old 11-29-2010, 01:41 PM Thread Starter
yea I am fixing it for a buddy and dont usally work on four wheelers. I work a lot on dirt bikes with 2 strokes but not to much experience with 4 stroke four wheelers with electric starts without a kick start
post #4 of 9 (permalink) Old 11-29-2010, 06:48 PM
cookies's Avatar
i have a pdf of a 2003 predator 500 service manual. not sure how much changed over those 2 years but if you want it i can try to get it to you somehow.
cookies is offline
post #5 of 9 (permalink) Old 12-01-2010, 01:57 PM Thread Starter
yea that might work if you can send it to me on here or my email eagles22793@aol.com thanks
post #6 of 9 (permalink) Old 12-05-2010, 11:02 AM Thread Starter
I found out that it will only get spark when you turn the key on and then crank it but only spark once. everytime the key is turned off then on and cranked it will get one spark. The switch in the trottle was doing this. I hooked the brown wires together and cut the black wire. It still dose not start after getting spark. It keeps jumping timing everytime i set the timing and try to start it and take it back apart then the timing is off.
post #7 of 9 (permalink) Old 01-19-2011, 04:26 PM
bvisailer's Avatar
im having the same problem with mine...when i set the timing...which is just linning up the dots...it seems fine but then after a couple cranks, air/fuel will start coming out of the carb backwards...not sure why it is doing this...
bvisailer is offline
post #8 of 9 (permalink) Old 01-19-2011, 05:29 PM Thread Starter
i took it further apart and found out that two valves were bent. That takes care of the starting issue but then it jumping timing not sure. I am just gonna replace the cranks shafts, bottom timing chain gear and new chain to makesure everything is brand new.
post #9 of 9 (permalink) Old 01-19-2011, 06:48 PM
cookies's Avatar
btw, that service manual (for the 03 pred 500) is posted up here on the forums. sorry if i didn't get back to you about it.
Service manuals
cookies is offline
Valve Job polaris Predator 500 fire0501 ATV Repair and Maintenance 8 02-22-2013 06:21 PM
03 polaris predator blksportsman ATVs For Sale 0 08-31-2010 12:53 PM
Polaris Predator engine yzryder125 Polaris Predator 3 08-21-2010 04:07 PM
polaris predator going though batterys Riley Polaris Predator 0 07-28-2010 08:20 AM
2007 Polaris Predator 500 redneck2725 2007 0 02-28-2010 02:45 PM
