Old 08-23-2009, 10:15 AM
Predatorhunter's Avatar
Member #1169
93 Polaris 4X4 Maintenance Questions
Picked up a used 93 (I think) 350 Liquid Cooled 4X4 and it's got a few problems I need to work out.
First and foremost I'd like to get my hands on a maint manual if someone has one or knows where I can find one online. (Polaris doesn't go back that far.). ANSWERED - ORDERED ONE
1. Overheat light comes on - Apparently there's a Radiator Thermo Switch and a water pump. I'm not sure if water is actually circulating or not. The resevoir level increases when it gets hot but does not overflow. (Fan does run for a couple of minutes when I turn the engine off.) Does the thermo switch control just the fan or does it control the flow of water? My second guess would be the impeller in the pump is bad but only because that's harder to get to.
2. Belt Replacement - Will I need any special tools or will a socket do the trick? Any tips on what to watch for and if there's any surprises would be appreciated.
Thanks,
John
Old 08-23-2009, 10:22 AM
http://www.repairmanual.com/motorcycles/0/54
And welcome to the board!
350 polaris 4x4
93 polaris
93 polaris 350
93 polaris 350 4x4
93 polaris 350 manual
93 polaris 350l
93 polaris 350l 4x4
93 polaris 400
93 polaris 400 4x4
93 polaris 4x4
93 polaris atv
93 polaris not charging
polaris 350
polaris 350 4x4
polaris 350 4x4 atv
polaris 350 liquid
polaris 350 liquid 4x4
polaris 350 liquid cooled
polaris 350 liquid cooled 4x4
polaris 350l 4x4
