2002 polaris magnum 500 front differential - Polaris ATV Forum
Old 12-09-2010, 09:34 AM
fattkt77's Avatar
Member #9111
Hello I was wondering if anyone had a diagram of how to tear down a front differential on a 2002 polaris magnum 500. The input shaft seal is leaking and I need to know how to repair it. It doesnt look to be to hard just want a diagram to use as a guide. Better safe than sorry. Also has anyone done this before and how hard was it?
thanks and hope to get some replys on this matter pretty quickly. I need to start on this asap. I'm doing the work for a friend and would like to get this back to him asap. so he can use it to hunt with before deer season is over.
Old 12-09-2010, 11:04 AM
philjbergman's Avatar
Member #8596
You should be able to change the seal with just taking the propshaft off. If you want to see a parts diagram we have them on our website. hit-the-gas.com.
2002 polaris front axle diagram
2002 polaris front differential
2002 polaris magnum 4x4 front differential schematic
2002 sportsman front differential
deferetal lock on polaris magnum 500
gear ratio for polaris magnum 425 differentials
polaris 425 gear ratio
polaris 500 2002 differential diagram front
polaris front differential diagram
polaris magnum diagram
what is the gear ratio of a polaris magnum 425 front diff
Polaris 330 magnum rear differential clicks when I go backwords and forwards Dag647 Polaris Magnum 4 02-23-2011 04:02 PM
2002 polaris 325 magnum 4x4 problems tommygirl ATV Repair and Maintenance 4 11-14-2010 04:03 PM
Sportsman 700 front differential zentar ATV Repair and Maintenance 1 10-07-2010 05:35 PM
02-05 500 or 700 sportsman front Differential darin ATV Parts for Sale 1 07-12-2010 08:21 PM
2004 700 EFI front Differential darin ATV Repair and Maintenance 2 07-12-2010 06:06 AM
