Old 08-23-2009, 06:16 PM
allenpace's Avatar
Member #1175
500 efi starting problems
My 2008 500 with efi is taking to long to start. The motor is turning over fast so the starter is not the problem. I have to try to start it 4 or 5 times before it does start then it runs find. I have drain fuel tank and change fuel filter. the 4 wheeler has about 980 miles on it. When the bike was new it would start right up. thanks for help or advice on fixing this problem.
Old 08-23-2009, 07:58 PM
Old 08-24-2009, 10:30 AM
jgalbraith's Avatar
Member #1144
could it be the spark plug, or maybe the air filter?
2008 SPORTSMAN 500EFI HO.....STEALTH BLACK....BRUSHGUARD....RACK EXTENDERS FRONT & BACK....POLARIS FACTORY WINCH....FACTORY ALLOY WHEELS....
Old 08-24-2009, 12:02 PM
imhuntingcrazy's Avatar
Member #767
Ohm test your stator, and check your fuel pressure. Let me know what you find.
Old 08-24-2009, 08:10 PM
nd4spd's Avatar
Member #1163
mine did the same when it was warm but once it got cold (winter) it wouldn't start at all and the pull start wouldn't budge; warranty changed out the started and who knows what else.
Old 08-25-2009, 04:40 PM
allenpace's Avatar
Member #1175
thanks
I have had fuel pressure check and it is OK. I will try to check the stator ohms next. If there is any more Ideas I would like to here them thanks for all the info . If I get it fix I will post what I did so maybe it can help someone else.
fual presure test onpolaris atv
