08-23-2009, 08:10 PM
Member #975
09 850 XP EPS CV boot replacement?
Does anyone have any experience in changing the inner, left, front, CV boot? Mine is torn.
From what I see I will need to remove the front tire and hub.... by removing the ball joints and tie rod end. Then the axle will pull out of the front diff.
Do the repacement CV boots small end stretch over the u joint?
Any help would be appreciated.
2008 Polaris 700 X2
2008 Canam Outty 800 XT
2009 Polaris 850 EPS
08-24-2009, 06:31 AM
Member #953
You should not have to remove the tie rod, but you might have to loosen the bottom shock mounts. You will have to remove the outer closest to the wheel CV joint and boot to get the new one on and then put the old boot on and tap the Cv joint back on to the axle. Make sure you pack that thing back up with grease. The outer CV joint is easier to tap off the axle than the inner one. There are small snap rings that hold the inner and outer CV joints in place. In most cases you can re-use the CV boot clams, and the tool is not needed. you can use needle nose plyers, but the tool is a little easier to use but will cost you $40 to $60 dollars. there is some good videos on U-tube on how to Change the CV boots on an ATV. you might want to check it out. Hope that helps you.
08-24-2009, 07:37 AM
Member #975
Thanks for the info, I did view some of the youtube videos on CV boot replacement and I think I have a better idea of what to do.
I just hope that it goes well.
My dealer here in Canada has not sold one yet I guess I am the first one. They do not stock it so it is on order. 50.00cnd dollars I thought is a little excessive.
2008 Polaris 700 X2
08-29-2009, 07:58 AM
Member #975
Anymore tips? Like what I have to take apart in order to remove the shaft?
2008 Polaris 700 X2
08-31-2009, 03:57 AM
Member #953
First remove the wheel then the castle nut with the cotter pin. Remove the wheel hub,
remove the bottom bolt on the A arm, this has a cotter pin also. you will probably have to lossen the bolts on the bottom of the shock to get the wheel hub to move. pull down on the axle to get the shaft out of the hub. then you can give the axle a good tug and it should come out with no problems. good luck.
2007 polaris ranger 700 rear hub how to take it off, 2008 polaris front cv shaft removal, 2009 polaris cv boot replacement, cv boot replacement on polaris 850, how do i change a front boot on a 2008 ranger xp, how do i take off the cv boots on a 2007 polaris ranger 700 crew, how to change a axle boot on a polaris ranger 700 xp, how to change cv boot on polaris ranger, how to re grease a cv axle, how to take off inner tie rod boot on polaris ranger, inner cv joint replacement on polaris xp ranger, outer boot front for a ranger 2008 polaris xp, polaris 850 cv boot, polaris 850 cv boot replacement, polaris atv forum boot replace, polaris ranger cv boot replacement, polaris ranger cv joint replacement, polaris ranger tie rod boot torn, tie rod boot torn on polaris ranger, utubep0larisatvccvjointbootreplacement
