95 Sportsman Voltage Regulator???? - Polaris ATV Forum
Old 12-19-2010, 09:34 PM
craig_ryan's Avatar
Member #10273
I have an old 95 sportsman and it has given me nothing but problems since the day I bought it. The last owner was a real piece of work. Especially when he failed to tell me that he took the oil injection off the bike and was using the oil resevoir as the coolant tank, so after checking the oil and filling the tank, I filled the entire cooling system with 2-stroke oil and cooked the rings. Anyways, the electrical is a real mess too. The battery won't charge, and after blowing 2 sets of headlights I desided to check the voltage regulator.....only if there was one on the machine!! I may be wrong but I believe it is located between the front grill and rad. My question is: When I buy a Volt Reg, where the h*** do I plug in the wires? If someone could show me a pic or a readable diagram you would save me soo much time/money. I do all my own repairs so I would rather burn the thing rather than bring it to the dealer.
Old 12-20-2010, 05:34 AM
Old 12-20-2010, 07:27 AM
craig_ryan's Avatar
Member #10273
I have looked at that schematic many times but it doesn't show where to plug the wires in. Like I said, there isn't one on the bike now so I have nothing to go off of. If someone could get me a picture of their's then I would be able to figure it out I think. Thanks anyways.
Old 12-20-2010, 11:20 AM
cookies's Avatar
Member #8052
um the diagram shows exactly where the voltage regulator mounts to the frame. the wires are all color coded. what else more do you need to know?
Old 12-20-2010, 12:30 PM
craig_ryan's Avatar
Member #10273
I think I just figured it out. While looking at the wiring diagram in my service book I couldn't make any sense of it. Then I looked one page back to the 94 Big Boss, and it is almost exactly the same....moved a few wires around and seems to be working now, no spike in volts when reved up, it was spiking to over 20V before. It has the 3 wire regulator instead of the 5 wire. Who knows, maybe the bike is more of a Frankenstein than I originally thought. cookies, what I was looking for was where the voltage regulator plugged into, as there isn't one there now, and I couldn't see any loose wires. Thanks for the reply though.
Old 12-20-2010, 01:55 PM
tt425's Avatar
Member #3687
Look on the frame near the gear shifter it should have a decal with a model number begining with a W_ _ _ _ _ _ followed by numbers. The 2 numbers after the w is the year model.
1995 polaris sportsman 400 wiring diagram
1995 polaris sportsman voltage regulator
95 polaris sportsman 300 voltage regulator
95 polaris sportsman 400 voltage regulator
atv polaris rectifier regulator schematic
pictures of regulator on 425 polaris atv
polaris 1995 400 voltage regultar reading
polaris voltage regulator diagram
polaris voltage regulator wire colors
testing voltage regulator 95 polaris sportsman
where is regulator on polaris sportsman 95
wiring diagram for a 1995 polaris sportsman voltage regulator
Voltage Regulator Quantum673 ATV Repair and Maintenance 8 09-20-2011 09:46 AM
2005 Polaris Sportsman 700 - Where's my voltage regulator? Koko ATV Repair and Maintenance 3 11-17-2010 07:29 PM
voltage regulator location 2000 sportsman 500 carmelo Polaris Sportsman 2 10-20-2010 05:31 AM
Wtb arctic cat voltage regulator tt425 ATV Parts for Sale 0 09-07-2010 02:24 PM
98 Sportsman 500 Voltage Regulator Muddermucker ATV Repair and Maintenance 0 04-18-2009 12:03 PM
