fuel filter - Polaris ATV Forum
Old 12-21-2010, 10:36 AM
maverick11's Avatar
Member #3694
fuel filter
I want to change my fuel filter. Im sure it hasn't been done since the quad was new in '06 but polaris wants around $25 for theirs and that seems OUTRAGOUSLY high for a fuel filter when i can get a universal fuel filter that i have used for other quads for just a few bucks. is it a must to use the polaris filter or am i fine with the universal filter? any other cheaper recomendations?
Old 12-21-2010, 11:22 AM
tt425's Avatar
Member #3687
A good fuel filter for a car is about $15 and a cheaper one is about $8. On fuel injected vechiles it is very important that you have the right micron rating media in the filter. Otherwise you stand a chance of getting trash in the injectors and clogging them. That repair bill could get expensive. I would pay a few more dollars and use an o.e.m. filter unless you can get the micron rating and match that filter excatly and trust the person giving you this information. Thanks
Old 12-21-2010, 11:50 AM
bakada's Avatar
Member #2821
Not positive on this but I think the filter has special pressure fittings and requires a special tool to take off. Could be wrong. If you can get it off take it to an auto parts store like Napa and have them try to match it. It amazes me what they have been able to match. Polaris out sources most of there parts and so they are used in other vehicle applications and therefor available usually for half the price.
04 Sportsman 700 efi black and silver, Big Gun Evo exhaust and tuner,3 light mod,reverse override,bar and thumb warmers,Moose pregressors,Black Rock wheels,Polaris(warn) winch and plow, 2 inch receiver, Filtermag.
00 Magnum 325 not very HO green, rolled, wrecked and rebuilt,heated grips and thumb warmer, Filtermag.
Old 12-21-2010, 01:44 PM
Manaen's Avatar
Member #6699
yeah as said already stick with the OEM part. On an efi model it is important that the filter also be able to handle the pressure of the EFI system as well. $25 seems reasonable considering you will probably only go through 2 of them in the life of the ATV. It's not like a car where you are running 1000's of gallons through it.
Old 12-21-2010, 01:53 PM
tt425's Avatar
Member #3687
I have worked in auto parts for over 20yrs. It is more a liabiltiy issue. If the filter is not designed for the machine and causes engine damage the filter manufacturer is not responsible. Visit wixfilters.com to learn more.
Old 12-21-2010, 03:41 PM
maverick11's Avatar
Member #3694
So if its only 4 years old do I need to replace it. Ill just let it go a few more years if I can
Old 12-22-2010, 10:05 AM
Manaen's Avatar
Member #6699
its not really a matter of years, but how many miles and how it was stored over time. Also if you ever used a gas can with some type of dirt in the bottom them maybe. But usually a properly maintained atv will probably not need a new filter after only 4 years. But Only you can answer that question.
2004 polaris fuel filter location
2004 polaris sportsman 500 fuel filter
2004 polaris sportsman 500 fuel filter location
change fuel filter on polaris ranger
changing fuel filter on 2008 800 polaris atv
fuel filter
my 2010 polaris atv is efi and i cant find the fule filter where is it located and how do i change it
polaris fuel filter replacement
polaris ranger fuel filter change
polaris sportsman fuel filter
polaris sportsman fuel filter location
where's the fuel filter on a 2009 polaris 500 sportsman
2004 polaris 700 sportsman fuel filter? waltdiggity ATV Repair and Maintenance 3 03-05-2013 07:23 PM
fuel filter crtcn2112 Polaris Sportsman 6 06-08-2011 05:00 PM
Sportsmanx2 500 fuel filter duane Polaris Sportsman 0 10-05-2010 08:53 PM
fuel leaking into air filter tonyv ATV Repair and Maintenance 7 01-18-2010 07:48 AM
2006 sportsman 500 HO EFI FUEL FILTER orlow Polaris Sportsman 2 06-27-2009 09:45 AM
