08-31-2009, 09:40 AM
Member #1257
'02 Scrambler 400 4x4 rear shock
Hello all,
I just signed up and haven't had time to search all the threads yet, so if this question has been already answered, sorry.
I just traded off my 400EX for this '02 Scrambler 400 4x4.
The rear shock is really slow on the rebound. I'm sure it needs a fresh nitrogen charge and probably a rebuild. I'd like to try and charge it first before tearing it all the way down though.
Is there any way to charge this up myself or do I need to take it to a suspension shop?
I haven't even had the chance to see what kind of fill fitting it has yet.
Thanks for any advice you folks can give.
JP
08-31-2009, 11:25 AM
Member #552
You will need special tools to recharge the shock. I would just have it rebuilt.
08-31-2009, 12:05 PM
Member #1257
any idea what that might cost to get it rebuilt?
Any suggestions on where to send it for that?
I'm wondering if it might not be cheaper to find a good used on on ebay. I've seen several for just under $100.
08-31-2009, 12:33 PM
Member #552
Ever used one I have ever seen needs to be recharged, so you would be better off having yours rebuilt. I rebuild them for 40.00 a shock plus parts.
08-31-2009, 04:28 PM
Member #1257
Ok, how much do parts usually run and what all gets replaced?
I can take the shock off the atv and ship it to you.
What is your normal turn around time?
Right now, it pushed down fairly easily and comes up kinda slow with a nasty squeaking kinda noise. The squeaking could be coming from the swingarm bearings though, I haven't had time to check it out. However, the noise is mainly on the return stroke and I would think the swingarm would squeak both ways.
And just out of curiosity, what does a heavier spring cost? I'm a 370 lb rider.
Thanks, JP
09-01-2009, 07:41 AM
Member #552
The rebuild kit is 25.00 which includes all parts to rebuild the shock. We could re valve your shock per rider weight this would be an additional 30.00 to 40.00 depending on what valving needs to be used.
09-01-2009, 09:11 AM
Member #1257
That sounds good.
I'm not so worried about the valving. I'm just a casual rider/slow rock crawler. I just thought maybe a heavier main spring might help to hold up my weight.
Does your rebuild cost include the return shipping?
How long will it take to get it back? (I will need it for deer season in November)
Thanks again for your help and info, JP
09-01-2009, 09:36 AM
Member #552
No shipping will probably be 10.00 to 15.00.
2000 polaris scrambler rear shock, can you service the rear fox shock on a 2000 polaris scrambler 400, charging atv shock, check rebound on scrambler 400 suspension, fix rear shock on polaris scrambler, how to fill nitrogen on polaris scrambler fox shock, how to rebuild a polaris scrambler rear shock, installing scrambler rear shock, polaris 2000 scambler 400 rear shock, polaris 400 rear shock length, polaris scrambler 400 4x4 rear shock, polaris scrambler 400 rear suspension, polaris scrambler rear shock, polaris scrambler rear shock noise, polaris scrambler rear shock rebuild, polaris scrambler rear slow rebound, scramb;er rear shock, squeaky rear shock polaris scrambler, suspension rebuilding mn, who rebuild rear shock on scrambler 400
