Old 09-01-2009, 06:35 PM
joeschmoes's Avatar
Member #1271
2004 Polaris Sportsman 400 4X4 Guage/4X4 Problem
I have a 04 Sportsman 4X4 and none of the guages work. The 4x4 button does nothing and the reverse override button does nothing. I have taken the top of the pod off and everything is hooked up. Any suggestions on the problem would be appreciated.
Old 09-01-2009, 07:23 PM
Old 09-02-2009, 09:19 AM
Dirty Dawg Dale's Avatar
Member #552
If the speedo is bad the 4 wheel drive will not work along with many other functions. The speedo head is the brains for the whole machine.
Old 11-24-2009, 04:34 AM
CrownHawg's Avatar
Member #2068
On this same subject, I have a 2004 700 EFI Sportsman with a little over 1000 miles. This thing has ran perfect since new, but the other day the speedo and guages went crazy. The needle would jump around and all the led indicators would flash. I can turn the key off, wait a second and turn it back on and occasionally it will be ok, but the 4WD indicator stays on. This machine is stored inside and the headlight unit has not been underwater that I know of. Could this just be the computer is bad and I have to replace? If so, how much are those puppies?
04 polaris sportsman 400 4x4
2004 4x4 polaris sportsman 400
2004 polaris 400 4x4
2004 polaris 400 sportsman
2004 polaris 400 sportsman 4x4
2004 polaris scrambler 400
2004 polaris speedometer problems
2004 polaris sportsman 400
2004 polaris sportsman 400 4x4
2004 polaris sportsman 400 4x4 not working
2004 polaris sportsman 400 problems
2004 polaris sportsman 400 reverse troubles
2004 polaris sportsman 4x4 problems
2004 polaris sportsman troubleshooting
2004 sportsman 400 trouble shooting
2004 sportsman 4x4 problems
how to crosswire polaris 4x4 2004
how to fix speedometer on sportsman 400
trouble shooting 4x4 on 2004 polaris sportsman 400
trouble shooting for 2004 polaris sportsman 400 the power flickers
