I have a 1999 polaris magnum 500. The spedometer has quit working along with the 4x4. Can someone give me detailed advice on how to correctly bypass the 4x4 wiring that runs through the spedo?
i can point you in the right direction, this has come up before and this fine gentleman (emike) has make an easy to follow HOWTO with some nice pictorials.
I did this fix on my 01 sportsman before I was on this forum I did it in the speedo pod. Took a bit to find what 2 wires to tie into but works great. On my quad it was the 2nd wire in on each side of the 6 wire plug on the speedo. Just added a jumper wire between them. I had power to the hubs but no ground out of the speedo.
113.2K members
