Old 01-12-2011, 12:25 PM
Dillon1483's Avatar
Member #9171
Polaris Winch Skipping
Winch skips and doesnt lift plow. Almost like a bike chain being too loose. I took the winch off. Any suggestions on whats causing it? I checked the engage and disengage lever. It doesnt seem to click all the way. On disengaged i can pull it out freely but in engage mode I can still pull it out but with difficulty.
Old 01-12-2011, 12:46 PM
Must be bad gears.
Old 01-12-2011, 01:41 PM
Dillon1483's Avatar
Member #9171
Angry winch
opened up the winch everything looks ok
Figures it happens when I most need it
Old 01-12-2011, 03:34 PM
cookies's Avatar
Member #8052
this happened to me. too much dirt got inside the winch and pushed something or other apart. long story short, one of the planetary gears ended up stripping out a ring in the plastic case. luckily the case was only $27 from warn.
Old 12-28-2011, 06:23 PM
redbull's Avatar
Member #21659
I'm dealing with the same thing with my polaris 3500lb winch.Spools out and in but i can stop the in spool with my hand and i can pull the rope out when its engaged not in free spool. It doesn't come out easy but i can get it to come out. I tore it completely down and all the gears are fine. Put it back together and still the same problem. HELP!!!
atv winch failure
atv winch repair forum
fixing a polaris winch
how to fix a polaris winch
how to fix gear in warn winch
how to repair a winch
how to repair polaris atv winches
how to repair polaris winch
my atv winch skips when i pull with it
polaris winch
polaris winch failure
polaris winch failure skipping
polaris winch failures
polaris winch planetary gears
polaris winch repair
polaris winch skipping
winch skipping
Polaris GII Plow Mount, KFI Winch Mount, and Warn Winch Stealthepooty ATV General Discussion 8 01-24-2011 04:00 PM
pure polaris winch blt ATV General Discussion 7 01-14-2011 03:29 PM
WTT: Polaris Brush guard/winch mount for standard winch mount Thomasj ATV Parts for Sale 3 09-29-2010 01:39 AM
Bad Polaris winch? TAC 338 ATV General Discussion 3 05-22-2010 01:54 AM
Polaris 3500 Winch bandit59 ATV Visual & Body Modifications 2 02-10-2010 01:16 PM
