ever welded a broken axle? - Polaris ATV Forum
post #1 of 4 (permalink) Old 01-18-2011, 02:00 PM Thread Starter
turbocav22's Avatar
Im sure somebody has tried it, and im curious to as how long it lasted...without getting in to the whole theory of heat and what it does to the metal etc. I already know this. Also, will a 2002 sportsman 500 front cv axle fit a 2001 400? they look similar and the part number is only different by 1.
turbocav22 is offline
post #2 of 4 (permalink) Old 01-18-2011, 05:00 PM
pieguy03's Avatar
My brother in law who is a welder, welded the axle on his brute force. He got one ride out of it before it broke. Personally I would not want to rely on a welded axle when out on a trail.
pieguy03 is offline
post #3 of 4 (permalink) Old 01-18-2011, 05:10 PM
whalebus's Avatar
yes you can weld it if you have to.the best way is to sleave it with some dom or hrew tubing but schedule 40 will work.also drill a couple of 3/8 holes in the sleave so u can plug weld it to give it more welds than just the ends of the sleaves.We used to sleeve stock stearing linkages on our jeeps and you would be suprised how much strength it gives it.It will break the joint before the welds will break
whalebus is offline
post #4 of 4 (permalink) Old 01-19-2011, 03:39 AM
2001sportsman400's Avatar
Yes an axle out of a 02 500 will fit a 01 400.
2001sportsman400 is offline
Broken gearcase? 2001sportsman400 ATV Repair and Maintenance 13 04-09-2012 09:41 AM
Broken Piston, should i buy? tennyis Polaris Scrambler 7 01-11-2011 07:38 PM
wet and broken sray76 ATV Repair and Maintenance 7 03-23-2010 10:10 PM
Shifter broken is this bad jamie-warner Polaris Sportsman 5 11-17-2009 06:33 AM
Broken Gorilla Axle lockedupLJ Polaris Sportsman 1 07-26-2009 05:29 PM
