Bad tps - Polaris ATV Forum
Old 01-03-2017, 06:47 AM
Nailbender's Avatar
Member #96850
Bad tps
cause a very high idle??? Shut machine off and restart seams to run fine?
Old 01-03-2017, 06:51 AM
cxcmoto's Avatar
Member #19300
Send a message via AIM to cxcmoto
I had this problem and it turned out to be dirt in the throttle body. I removed the throttle body, cleaned it, and it was fine after that. I never did find out how dirt got into the throttle body.
In my case, sometimes I could blip the throttle a few times and get it to come all the way back to a regular idle.
Old 01-03-2017, 07:15 AM
Nailbender's Avatar
Member #96850
Ill let you know. Dealer said new TPS will be in on Friday. He said it was an electrical issue?
Old 01-03-2017, 08:21 PM
erikking68's Avatar
Member #87154
If tps is bad it normally will give you a check engine light
Old 01-11-2017, 04:43 AM
Nailbender's Avatar
Member #96850
Was not the TPS sensor dealer is not sure . I asked him to check the harness for a broken wire
Old 01-11-2017, 04:52 AM
Nailbender's Avatar
Member #96850
So frustrated dealer cant figure it out. Paid twice at $80 each them saying they fixed it and didn't
Old 01-16-2017, 03:54 AM
Nailbender's Avatar
Member #96850
Now the dealer thinks its the IAC??????????????// this is getting old
Old 01-16-2017, 04:45 AM
Nailbender's Avatar
Member #96850
anyone have any other ideas of what it could be?
Old 01-16-2017, 06:03 AM
Member #1958
Probably is the IAC or the vacuum hose to it. The IAC likely just needs cleaned or the vacuum line is leaking. Both are easy fixes that take only a few minutes but at the dealer its gonna cost ya $$...sounds like it already has.
A bad TPS won't cause high idle. If its bad it usually causes rough or NO idle and/or a dead spot in the throttle. I've never known a bad TPS to give a trouble code either.
Old 01-16-2017, 06:07 AM
Nailbender's Avatar
Member #96850
II hope it is the IAC ready to get this little project over with Thanks for the imput once I get it back ill let everyone know what it was incase anyone else has this issue?
Confirm a bad TPS 2010 850 XP EFI TBark Polaris XP 2 12-18-2016 12:03 PM
Newbie 700 ranger TPS Troy78 ATV New Members 2 09-23-2016 05:04 PM
TPS Adjustment on New Throttle Body Assembly pglover19 Polaris Sportsman 2 09-14-2016 06:20 AM
2014 Sportsman 570 TPS Questions Hammer4543 Polaris Sportsman 570 1 05-16-2016 10:54 AM
Bad eBay Sellers chronix79 Around The Garage 9 02-06-2016 09:47 PM
