slow tire leak around rim - Polaris ATV Forum
post #1 of 9 (permalink) Old 02-02-2011, 06:15 PM Thread Starter
ncmtns's Avatar
I have a 25x11-10 Goodyear Tracker with a slow leak on the rear of my '96 sportsman. I soaped it up and it's coming from around the outer bead/rim connection (about 1/4 of it). Has anyone dealt with this before? Any help is greatly appreciated..... thanks.
ncmtns is offline
post #2 of 9 (permalink) Old 02-02-2011, 06:47 PM
pieguy03's Avatar
I have had a couple leaks around the rim over the years. Everytime it has been some sand or a small stick that has broke the bead. I take it to a local tire shop and they pull the tire off, clean it up good and put some type of black sealant around the bead before putting tire back on. Never have any issues again going this route.
pieguy03 is offline
post #3 of 9 (permalink) Old 02-02-2011, 08:16 PM
full eyes's Avatar
Yeah same as answer as that guy
2008 500 ho touring
26 mudlites
itp 212 alloys(black)
deluxe bumper
G1 plow
full eyes is offline
post #4 of 9 (permalink) Old 02-03-2011, 04:09 AM
NickS's Avatar
I got a stick jabbed between the wheel and tire after the last ride, and it went flat. I pulled it out best I could, but it would still go flat every couple of days. I sprayed it with some soapy water, and it was on the bead like yours. I was just going to do what everyone above did and take it to a local shop. I needed to slime my tires anyway, and figured what the hell. Put the amount it said in all tires, and there was still a little left over, so I put that in the tire leaking. It's held air fine now for 3 weeks so far, so the slime seemed to fix it.
2005 Polaris Sportsman 400 4x4
3 Headlight Mod / 14" ITP SS312 / 26" Maxxis Zilla's / Under Body LED Accent Lights
2010 Decals
NickS is offline
post #5 of 9 (permalink) Old 02-03-2011, 05:01 AM
tt425's Avatar
If nothing between the rim and tire it's possible the rim is bent. Hit the rim where it's leaking with a hammer while the tire is fully inflated that might stop the leak. You might want to use a board or something to protect the rim while doing this. I did this on a utility trailer tire and it worked.
tt425 is offline
post #6 of 9 (permalink) Old 02-03-2011, 05:10 PM
full eyes's Avatar
Hi Nick...I have never used the slime before but I have used other products that are close to the same thing. They do work to seal but when it is time to change your tire it makes a hell of a mess..Any time I have done it it take a lot of scrubbing with a wire brush..Mabey slime is better I dont know havent seen this product in Canada...Hope it works out ok..just wanted to give you the heads up!!!!
2008 500 ho touring
26 mudlites
deluxe bumper
G1 plow
post #7 of 9 (permalink) Old 02-03-2011, 06:24 PM Thread Starter
ncmtns's Avatar
Well, for better or for worse later, I tried the slime and it seems to have stopped the leak. The rim is in good shape... still not sure why I had this issue at all. Rode about 5 miles this evening and all seems to be good. Will update thread if anything changes.... Thanks for the help to all!
ncmtns is offline
post #8 of 9 (permalink) Old 02-05-2011, 05:05 AM
NickS's Avatar
Sounds like that's for the tire shop to worry about, not me.
2010 Decals
NickS is offline
post #9 of 9 (permalink) Old 02-05-2011, 06:40 AM
cwlongshot's Avatar
I completely agree with pieguy03. Our tires do alot for us and maintenance of them is a very good thing. Now ATV's may be a newer thing to me but 20+ years driving jeeps over the same terrain isn't and its a same, same kinda thing. In the jeep because of the increased speed and miles. You can actually ruin a alum rim in short order if the sand is alowd to "grind" into the bead.
I pop one bead at a time, completely clean and re-seat yearly at least!! It's a good winter thing to do and isn't hard. I pop beads with a high lift and a bumper and a couple tire spoons in the summer.
You will need a compressor to re-seat the bead. I use a CO2 bottle that I carry in my jeeps. (Just like the soda fountains use)
To me SLIME is a last ditch operation. One thing when using it, GO FOR A RIDE AFTERWARDS!!! If you don't distribute the slime around the inside of the rim it cannot work for you. I don't like it simply because it makes a mess inside the rim and the tire changers HATE the junk on their tire machines!!!
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
slow 500 bogging sportsman 500 ATV General Discussion 8 01-18-2011 06:11 AM
Will this slow me down? davidhicks ATV Performance Modifications 2 05-20-2010 11:48 PM
slow trailboss 330 UPSguy Polaris Trail Blazer 2 02-18-2010 01:54 PM
4x4 slow to engage on 325 Mag sburn518 ATV Repair and Maintenance 1 02-06-2010 02:16 PM
4x4 slow to engage thepopeis1 ATV Repair and Maintenance 8 01-21-2010 11:22 AM
