weak spark? Please help! - Polaris ATV Forum
Old 02-04-2011, 09:23 AM
Polaris27's Avatar
Member #11696
I just bought a 2003 Polaris Predator 500. The other day it stalled out while idling and when I tried to start it would only backfire and run then stall. I changed the spark plug but no change. If you let it sit it would start up and run perfect until you rode for about 30 seconds then stall and backfire. Since then it sat for two days and not it wont act up. I think it had weak spark and thought maybe a weak coil or bad CDI unit. Any help or pointers i would greatly appreciate.
Old 02-04-2011, 10:37 AM
Hit.The.Gas's Avatar
Member #11694
Do you have a good battery? Predators need a fully charged battery to run correctly. If the battery is not fully charged it will have symptoms very similar. ~Phil
Old 02-04-2011, 11:06 AM
Polaris27's Avatar
Member #11696
The battery was fully charged good. It happened after riding it for ten minutes and now it runs perfect and I haven't touched the battery since.
Old 02-04-2011, 04:19 PM
DavTay's Avatar
Member #10823
Send a message via Yahoo to DavTay
Check the Cap to coil wire connection.
If the wire is rusty you would get an erratic weak spark.
If it is rusty you can cut a little off and reattach the cap.
Old 02-07-2011, 06:07 AM
Member #11694
Did you check to see if you have 12 volts when the machine is running? If your battery is good and your bike isn't charging it will slowly drain it until it won't run. Then if you let it sit, the battery goes back up to 12 volts again and repeats. Just a thought.
2003 polaris 90 predator weak spark
2004 polaris predator 90 weak spark
diagnosis weak/no spark on a polaris atv
polaris 90 intermittent spark#gsc.tab
polaris 90 predator light fire to plug
polaris predator 500 weak spark
polaris predator intermittent spark
polaris sportsman 90 weak spark
predator 500 coil failure symptoms
weak spark
2000 Polaris Sportsman 90 No spark/weak kennyy ATV Repair and Maintenance 4 02-01-2011 05:42 AM
Weak spark ford_boy ATV Repair and Maintenance 0 10-14-2010 03:04 PM
weak suspension joecl41 ATV General Discussion 5 10-06-2010 07:13 PM
2005 Sportsman 400 w/weak/no spark issue HELP!! mspeer7 Polaris Sportsman 1 07-16-2010 05:36 PM
Sportsman 90 weak Spark prinsloos ATV New Members 3 05-24-2010 02:40 PM
