Sportsman cam pics.... - Polaris ATV Forum
Old 02-07-2011, 12:37 PM
2001sportsman400's Avatar
Member #8639
This seems to be a problem with the sportsmans. The exhaust lobe on the cam wears off. I think that my carb float neeedle and seat being worn out caused this. I noticed that I had fuel in my air box. Drained it and didnt think anything else of it. Put a new needle and seat in it. Turns out that about 3 weeks later I realized gas had also filled my motor and diluted the oil so much it was like water. I also noticed it had very tiny sparkles in it. Messed with the carb thinking I had a clogged jet. Read somewhere someone said to check the exhaust lobe on the cam. Finallly popped the valve cover and found a bad cam. Here are pics of the cam and the exhaust rocker arm. Both are trashed.
Old 02-07-2011, 12:43 PM
Hit.The.Gas's Avatar
Member #11694
one problem the earlier sportsmans had was that sometimes the metal oil tank will collect condensation and because the oil flows near the bottom of that tank it can make the oil insufficiant if its not changed more often, they fixed the problem with the newer sportsmans plastic oil tank. it can be switched out.
Old 02-07-2011, 12:44 PM
Member #11694
also always run polaris oil
Old 02-07-2011, 03:49 PM
Nitro's Avatar
Member #8438
Wow, that's an incredible picture. Sorry to hear. Did you notice a lot of metal in the oil? I would think with that amount of damage it would show itself when an oil change is performed.
2002 Sportsman 400
Old 02-07-2011, 04:24 PM
Member #8639
Yes, I said that I did. Qoute "Turns out that about 3 weeks later I realized gas had also filled my motor and diluted the oil so much it was like water. I also noticed it had very tiny sparkles in it."
Old 02-07-2011, 05:01 PM
Nitro's Avatar
Member #8438
My bad. I had a similar issue in the fall but it was an intermittent issue. She would run for a while and then wouldn't run. She seems to run fine now but for piece of mind I'm going to pull my valve cover this spring to check the cam
2002 Sportsman 400
Old 02-07-2011, 05:22 PM
Member #8639
Yea the big pics make it hard to read sorry bout that.
Old 02-08-2011, 10:10 AM
Nitro's Avatar
Member #8438
How big of a task is it to get the valve cover off? I take it you have to remove the air box, front plastic, and gas tank?
2002 Sportsman 400
Old 02-08-2011, 01:34 PM
Member #8639
Isnt a big deal to me. But, I suppose its just up to each person on how far they are willing to go with any repair. It took me about 10 minutes to have the front clip plastics, gas tank removed.
Old 11-10-2012, 01:26 PM
Jeeping99tj's Avatar
Member #31045
Well I looked at the cam. There isn't much of a exhaust lobe. Has a real shape lobe and rocker arm is worn and has a groove. The exhaust lobe isn't really a lobe. Just goes up a little bit the flattens off and looks scored bad.
1998 polaris sportsman 500 camshaft removal
1998 polaris sportsman 500 camshaft replacement
99polaris ranger camshaft pic
cam
exhaust lobe on your camshaft for polaris sportsman 400
groove in exhaust rocker polaris 500
how to change a cam in a polaris sportsman 500
how to install cam in 2001 polaris sportsman
polaris sportsman 400 exhaust cam lobe
polaris sportsman 500 cam problems
sportsman 500 cam install
Any pics of Sportsman 400/500 in the back of your trucks?? WilliamBos Polaris Sportsman 33 10-10-2014 11:01 PM
Road Trip Pics-Michigan to Washington- Lots of pics! blueline15 Around The Garage 21 03-27-2013 04:27 AM
2011 Sportsman 400 HO with Glacier Plow pics glngib Polaris Sportsman 13 09-15-2011 02:19 PM
Pics of the new 850 Eps Cableguy657 ATV Media 17 05-06-2010 10:07 AM
first one to post pics of my 08 sportsman 500 chuckraduenz ATV Media 32 02-20-2010 11:22 PM
